Question about Xantrex Freedom Hf 1800 Inverter/charger
Running and not stopping
Running for long time with new battery
Dirt devil easylite 7.2 v does not hold charge. Can you suggest any fix? Thanks
Sorry to say that the batteries seem to be worn out. Usually this is caused by using it for to short a time each time you use it. Batteries develop a 'memory' after several short time uses, and can only be charged the time it 'Thinks' is a full charge. You can try running it until it almost stops. Then let it sit for about an hour turned off, then turn it on again, and run it till it almost stops. After doing that put it on the charger for 8 hours. Then run it until it almost stops again. then charge it again. That process sometimes breaks the memory problem. If not, you need new batteries- or a new dirt devil.
Jul 02, 2017 | Dirt Devil Vacuums
Bought new battery for the john deere gator ride on toy but only runs for a short time then battery needs recharging
Hi, How long does it run? Typically you should get at least 45 min of run time out a fully charged battery. If it's slowing gradually and dying in just a few minutes its the battery. If it's goign full speed and then stopping suddenly, it's probably the thermal breaker located in the shift mechanism.
Aug 25, 2014 | Peg Perego John Deere Gator HPX Ride on...
71 c10 not staying charged... new battery alternator fuses good and new voltage regulator
Maybe it wasn't running long enough to charge up the battery?
Stop trying to jump it, when you are having problems with it dying, take the battery off and have it charged. And/or buy a $20 voltmeter to see what the battery shows. If it says less than 12 volts, it is discharged, and needs charging. A good battery that is not run down should have at least 12.5 volts. A new battery that is charged should have very close to 13 volts, maybe 12.8 volts.
When you have the truck running, check the alternator for charging. You put the voltmeter right on the battery and check it again. This time, with truck running, battery should show at least 13.5 volts. That shows the alternator is working. A good alternator will put out about 13 or 14 volts-the regulator will keep it from going any higher to prevent problems, like a melting battery or electrical parts burning out.
I would say get the charging system working right, then address the problem of dying at stop lights. That could be a carburetor problem, if the alternator is working.
Aug 15, 2013 | Chevrolet Cars & Trucks
Elini New Yorker stopped running. could it need a battery? Where can I take it?
Yes, normally if a watch stopped running it needs a new battery. Well, you can bring it to the nearest watch shop in your area.
Sep 17, 2011 | Elini New Yorker Grand Chronograph Red...
2003 Jetta car will start and run for a few days, then all of a sudden, it stops running. It also seems to drain the battery. I replaced the battery twice with a brand new battery. I pulled the...
Not to disparage Advanced Auto, but you should check it yourself with a voltage meter-when the car is running, voltage should be over 14 volts, measure it at the battery posts AND at the reat post on the alternator-the readings should be within .02 volts of each other. A digital meter only costs $15 (at Advanced) and is a more accurate test than an alternator that has been removed from the car-when you test it out of the car, you are not accounting for poor connections that might be causing your problem in the first place.
Jan 23, 2011 | 2003 Volkswagen Jetta TDI
Hi Everyone, I have recently bought a new Iphone
Make sure that your WiFi is not left on all the time and that the signal is strong as weak signal affects the battery. Adjust the screen brightness to low and avoid using the phone for games etc to maximise battery life.
Oct 20, 2010 | Apple iPhone 3G
My watch is 8 months old and just stopped..the screen still displays the exact time and date that it died..but because it's digital if it was the battery the screen should have gone blank?!!
Best bet is to start by replacing the battery. At 8 months it'll be due for one soon anyway and a new battery may "reboot" it so it runs again. As a battery wears out it doesn't just stop, it may still maintain the display even though it stops keeping time. Also, new "e-ink" displays require no power to maintain the display 0 only to change it.
Apr 28, 2010 | Columbia Digital eBook Watch for Women
My 2003 PT cruiser dies at a stop sign and then it won't start
You may need a new battery (alternator will keep it running once jumped but if you stop, the idle may not keep the car powered long enough). If you've never replaced the battery, its about time - they have a life of about 5 years.
Jan 02, 2009 | 2003 Chrysler PT Cruiser
Xantrex Freedom Hf 1800 Inverter/charger Logo
Top Xantrex Televison & Video Experts
Electro Med Services...
Are you a Xantrex Televison and Video Expert? Answer questions, earn points and help others
