Question about Pentair Whisperflo 3/4 Hp 115/230v
Trying to install Flotec Dual Voltage pool pump. Instructions have an addendum which instructs how to turn dial to change between 115 and 230 but does NOT show me where wires go. Refers back to owners manual which is different config. Can anyone help?
    President:
  • Pentair Master
  • 1,378 Answers
The motor should have a diagram on it showing where line 1 & 2 go. It does not matter which of your two line wire goes to which post, as long as you put one wire per post and have the motor set for the correct incoming voltage, you'll be fine.
Posted on Jun 15, 2009
I need instructions of Melnor 304F timer for watering
From the Melnor 304f actual instructions:
Use 9V alkaline batter only! Flashing lighs indicate that the battery is low and needs to be replaced.
1) To start: Turn Dial to Off position and press ENTER
2) Set Time: set the current time and press ENTER
3) Start Time: set the time to start the first irrigation cycle and press ENTER.
4) Frequency: Set the frequency of the irrigation cycle e.g. twice a day = 12h and press entere.
5) Duration: Set the duration of the first irrigation cycle and press ENTER.
-- to change the duration
Turn the dial to the new duration and press ENTER
--to turn the water on manually
Turn dial to ON position.. The water will turn off automatically after 30 minutes.
-- to turn the water OFF
Turn the dial to the OFF position
Do NOT press ENTER when dial is in OFF position, otherwise the unit will clear the program, and you have to Reprogram the unit following the steps 2 through 5.
Jun 29, 2014 | Flotec Garden
Flotec pool pump motor just hums and pump does not come on
try blowing out the back of the motor around the electrical and inside the motor with compressed air, this sometimes will spark it back to lfe
Apr 30, 2012 | Flotec Pool & Spa
I replaced a one horse flotec sprinkler pump with a 1 1/2 horse pump. the one horse was wired at 115 volt/ 20 amp 12 gauge wire. the new pump is blowing the breaker.any suggestions ?
Your best solution would be to convert the circuit over to 230V assuming only the pump is on the breaker. Changing it to 230V will cut the amp draw in half and allow for the 12AWG wire to carry the load. You could increase the breaker rating but the wire is to small for the load and keeping it will lead to future problems if you leave the circuit as 115VAC.
John
Jan 25, 2011 | Flotec Pool & Spa
I have a 1 hp in ground Flotec pool pump. It is not pumping the proper flo. It makes noise when it starts but then clears up. The motor sounds good. How do I get a manual on the parts for the pump...
GOOD LUCK GETTING PARTS FOR THIS.. FRANK , IF WERE MY POOL I WOULD CHANGE THAT PUMP OUT TO A STA-RITE DURA GLASS.. FLOTEC IS A POOR COPY OF THE STA RITE.. OR YOU CAN CHECK THE IMPELLER IF IT IS PLUGGED WITH TRASH OR IT COULD HAVE A BAD CAPACITOR.. BRING IT IN AND HAVE IT CHECKED..
Aug 15, 2010 | Flotec Corrosion Resistant Convertible Jet...
I have a broken sump pump, Flotec model # FPOF360AC
Same pump, same problem. H/D sells the pumps, but no parts. Here's a link to a vendor of Flotec parts. http://www.pumpvendor.com/Flotec_Parts_List.html
Apr 01, 2010 | Flotec Simer/Flotec/Omni 2105 Swimming...
Pump keeps turning off
this pump needs about 21/4" of water to operate properly, this pump will not remove all the water from the cover and will cycle on and off as it looses prime. If the motor turns completely off, it may be a an issue with low line voltage. you can try using a lager gauge extension cord to try and fix it, otherwise have an electrician test the line voltage.
Here is a pdf of the manual:
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000049529.pdf
Sep 16, 2009 | Flotec Simer/Flotec/Omni 2105 Swimming...
I got a brand new Flotec 2 HP Jet pump and installed it but now it is overheating and smoke is coming out. Why is this happening and how can I fix it?
WAS YOUR NEW PUMP DUAL VOLTAGE? AS IN 115VOLT OR 220VOLT. IS IT WIRED FOR THE CORRECT VOLTAGE? NEED MORE INFO IF THIS DOESNT FIX. HOPE THIS HELPS. JODY
Aug 31, 2009 | Flotec Corrosion Resistant Shallow Well...
Schematic for wiring in a Flotec Pump
Remove end casing of Flotec motor housing they have a 115v/220v switch, turn to 220v, see website flowtec water. Flotec parts 1-800-365-6832
Jan 31, 2009 | Flotec Corrosion Resistant Shallow Well...
Pentair Whisperflo 3/4 Hp 115/230v Logo
216 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
