Question about Pebco Pro Tools 2900 Stand Hood Dryer 2000 Watts Model: ED2900
Need replacement part
The hooded shield is broken. Where can I purchase a new one?
Broken mounting bracket
Refer your inquiry to Masterbuilt.
Dec 21, 2013 | Masterbuilt 20010406 Deep Fryer
Bonnet cable brook on bmw 3 series
Okay, so the hood latch cable on your BMW 3 series has broken. Normally the cable itself will snap and a you can purchase a new cable that can be threaded through the casing and reconnected to the hood latch. You will need to get the hood open, so hopefully there will be some access to the hood latch mechanism from underneath the front of the vehicle.
Apr 27, 2010 | 1996 BMW 318
How do I replace the windshield washer nozzle on the 2003 Saturn Vue? I went to the dealer and purchased part number 22722205 but need to know how to remove the broken part and install the new part.
Open Hood,Remove 4 push pin retainers,remove wiper arms.If it's the pass side you will not need to remove wiper arms.Driver's will need arms removed
Apr 23, 2009 | 2003 Saturn VUE
Hood cable is borken can get hood open
if its broken at the handle inside the car use a pair of pliers to pull the silver cable if it is broken outside the car there is a black plastic shield on the underside of the car, remove it and the lack will be visible use a screw driver to release latch
Apr 13, 2009 | Buick Park Avenue Cars & Trucks
Changing of belt
Step 1: Lower handle to floor to change belt
Step 2: Remove the two screws from the top hood on the foot
Step 3: Lift hood to remove
Step 4: Lift right end of brushroll (the belt end)
Step 5: Remove and discard belt.
Step 6: Place new belt around motor shaft.
Step 7: Place new belt around brushroll pulley.
Step 8: Align left end cap with base. Push end cap securely into
place. Make sure the square on the brushroll cap is in
place
Step 9: Pull right side of brushroll to stretch belt. Secure right
end cap into base.
IMPORTANT
Step 10: Rotate brushroll by hand several full rotations to properly
position belt.
Step 11: Place hood back on cleaner. Replace and tighten
two screws.
Step 12: Return vacuum to upright position.
You can also download your user manual here which has instructions on how with diagrams
Dec 24, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Viking downdraft dipr 160r cable
IF YOUR MACHINE WAS BROKEN DURING INSTALL YOU SHOULD BE UNDER FACTORY WARRANTY IF IT WAS PURCHASED AT AN AUTHORIZED DEALER IT IS THE RESPONIBLITY TO REPLACE THE MACHINE AND TAKE THE OTHER ONE BACK TO THE STORE TO HAVE A AUTHORIZED SERVICER REPLACE OR REPAIR ANY DAMAGED PARTS. HOWEVER IF THIS IS NOT A NEW INSTALL YOU CAN PURCHASE THE PARTS FROM HADCO APPLIANCE PARTS
May 30, 2008 | Viking DIPR160R Stainless Steel Kitchen...
Diamond Shield Mitsubishi 55315
if either of u r close to michigan i have the above tv with no video possibly willing to part it out
Nov 11, 2007 | Mitsubishi WS-55313 55" Rear Projection...
BROKEN SHIELD
Behind the protective shield are two plastic layersright next to each other if the front one is not broken and the quality of the picture is good considering the damage to that specific spot on the screen you should not have to replace it,only remove whats left of the broken shield.Be careful not to scratch that front lens.
Sep 21, 2006 | RCA P61960 61" Rear Projection Television
Pebco Pro Tools 2900 Stand Hood Dryer 2000 Watts Model: ED2900 Logo
26 people viewed this question
Top Pebco Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Pebco Health and Beauty Expert? Answer questions, earn points and help others
