Question about Crock Pots & Slow Cookers
Auto shift What is auto shift
The Kenwood slow cooker has 4 settings Off Slow High Auto. What is the Auto for
Auto automatically selects slow or high depending upon time and cooking conditions.
Feb 24, 2017 | Crock Pots & Slow Cookers
On the dial there is off, low, high and auto. What does the auto do? If I select auto is there a timer on it that shuts the pot down after a time? Is fo what is the time.
There is no timer -- with the dial set to auto, a thermostat opens and closes turning the heating element(s) on and off to keep the pot at a fairly constant temperature. The high setting can continually boil the contents, and can burn the food if not stirred. The low setting is for keeping contents warm.
I'd use "auto", if the pot is not going to be monitored.
Charlie
Mar 27, 2011 | West Bend Crock Pots & Slow Cookers
What is the auto switch on a small crock pot for?
That is so that the crock pot goes on high heat to get things heated up faster and then shifts automatically to low after it is hot...so that it does not over cook your food when left for a whole day...
heatman101
Jan 12, 2011 | Rival Crock Pots & Slow Cookers
HOW TO USE AUTO SETTING
It looks rather like my slow cooker which has a 3 position switch with LOW, HIGH and AUTO.
AUTO uses a thermostat control to prevent the contents from boiling. Useful if being left unwatched. HIGH setting can cause burning if contents not stirred, and LOW setting is only of use to keep things warm. Hope that helped.
Oct 05, 2010 | West Bend 84384 Slow Cooker
Ronson slow cooker settings
Hi. I'm a Ronson Service Centre in Australia.
I grabbled this blurb from a Ronson Slow Cooker Manual.
On Setting 1 (Low) the Slow Cooker can operate all day and night if required.
When set to 2 (High) it is very much like a covered pot on the stove. Foods will cook in ½ the time required for 1 (Low)
When set to Auto, the Slow Cooker will cook on 2 until the food reaches a pre-set temperature, then switches to 1 and maintains a constant slow cooking temperature.
“Auto” is the ideal setting for someone leaving the house for the whole day as most food will cook for 8-9 hours and be ready to serve when they return.
Nov 24, 2009 | Crock Pots & Slow Cookers
No manual for my old Crock Watcher by Proctor Silex
The auto setting cooks on high for the first hour, then adjusts the setting to low for the remaining cooking time.
Auto Shift allows the slow cooker to heat up to high and then internally shift down to low, so it gives more flexibility in cooking time. Example: A certain recipe may take 4 hours on high, 5-6 hours on Auto Shift and 7-8 hours on Low.
Oct 19, 2009 | Crock Pots & Slow Cookers
Auto/shift button on a crock pot.
it does just what it says . its a great feature . in auto shift mode the pot will be on high untill it reaches full boil or a pre set time has gone by .... most people start there crock pots on high and turn them to low when it gets cooking .....this does it for you ... happy crock poting ...Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Mar 08, 2009 | Hamilton Beach Proctor-Silex 32190...
MANUAL
please rate if this helps fixya problem
respond with any other questions...thanks
Jan 14, 2009 | Hamilton Beach 33015
Older model General Electric crock pot
The auto button is ususally it startts off on high setting to warm up the crock and when it reaches a pre set temperature it will shift to med or low which ever is the next lower setting it will continue cooking at this setting unless you change it
Dec 31, 2007 | Crock Pots & Slow Cookers
Crock Pots & Slow Cookers Logo
Top Crock Pots & Slow Cookers Experts
tsalagi152
charles
Irene Tulloch
Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
