Question about Farberware 2.5L Single Deep Fryer, Stainless Steel
Replacement lid and cord
Need a replacement lid and cord for this devise.
In dire need for a lid and power cord for this blender
Power cord is pretty standard for appliances/desktop PCs/printers. I would try the local Goodwill, they all have a wall with cords for every manner of appliance. On any given day, my local Goodwill has them in black and grey. Or any electronics store will have them.
As far as the lid - I'm not sure if you lost/broke the entire thing or just the plastic cap in the center. That Jenn-Air center plastic piece is easily broken. Your local Ace Hardware or True value sells replacement Blender cap inserts. Glass center with aluminum washer/nut that screws on from below. Looks better than original and won't yellow.
Nov 28, 2012 | Jenn-Air JBL800 Work Top Blender
Cartrage replacement
From the user guide:
Cartridge Error (1102, 1203, 1204, or 120F)
1 Remove the print cartridges, and close the cartridge carrier lids.
2 Close the scanner unit.
3 Disconnect the power cord from the electrical outlet.
4 Reconnect the power cord to the electrical outlet.
5 If the button is not lit, press .
6 Reinsert the print cartridges and close the cartridge carrier lids.
7 Close the scanner unit.
If the error does not reappear, the problem has been corrected.
If the problem reappears, one of the cartridges is not working properly. Continue with the following procedure to
determine which cartridge is not working properly.
6 Reinsert the black (or photo) print cartridge and close the cartridge carrier lid.
8 If the error:
• Reappears, replace the black (or photo) print cartridge with a new one, close the cartridge carrier lid, and close
the scanner unit.
• Does not reappear, reinsert the color print cartridge, close the cartridge carrier lid, and close the scanner unit.
9 If the error reappears, replace the color print cartridge with a new one, close the cartridge carrier lid, and close
the scanner unit
Aug 19, 2012 | Lexmark X9575 InkJet Printer
I need a diagram of the fuse box, what amp each fuse should be and what devise it operates. A schematic? For a 1988 Dodge Dakota pick up.
The diagram should be with the fuse box, on my car the diagram is right on the top of the fuse box lid, otherwise, I would talk to a professional to get that kind of information
Jan 24, 2010 | 1988 Dodge Dakota
Spin safety switch not properly calibrated
Well if you can push the switch in by hand the switch is ok no need to replace.Depending on what type of actuator you have it may be that you could put a washer or two behind it to shim it out making it longer and more able to hold in the switch, Just a thought.
Aug 29, 2009 | Kenmore 2.1 cu. ft. Portable Top Load...
Remington electric tiller circuit breaker goes off
For about $20.00 you can buy 50 feet of 12 guage 3 wire yellow extention cord. You will then get all the amps you need to run your unit. If it still fails, you have a problem inside the tiller.
Tom MN
Jan 30, 2009 | Remington 109312 - 01 Garden Wizard...
Devise not responding
The same thing happened to me,
turn your camera on, hold down menu/ok button, click over to the wrench tool which is called the setup menu, scroll down to USB Configuration, click on it, then scroll to disk drive and select it.
Now try turning your camera off and then back on, connect USB cord to computer and you should be all right.
Nov 11, 2008 | HP Photosmart M525 Digital Camera
Farberware 2.5L Single Deep Fryer, Stainless Steel Logo
48 people viewed this question
Top Farberware Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Tom Chichester
Are you a Farberware Kitchen Appliances - Other Expert? Answer questions, earn points and help others
