Question about GE Kitchen Ranges
Jb850st1ss Control panel problems
Panel problem
Hello
Unplug the microwave from the wall outlet prior to disassembling.
Open the microwave door. Remove the screws securing the grill above the door opening to the microwave. Remove the grill.
Remove the screw located at the top of the control panel, which is now visible with the grill removed.
Lift the control panel up to release the tabs securing it in place. Move it away from the microwave.
Look at the rear of the control panel to any disconnected wires that may have caused the control panel to stop functioning. If wires are disconnected, reconnect them, reassemble the microwave and determine if the problem is still occurring. If the problem still occurs, replace the control panel.
Transfer the wires from the old control panel to the new control panel.
Move the panel back against the microwave's control panel housing. Slide it down to lock it into position.
Install the screw at the top of the control panel.
Replace the grill on the top of the microwave. Secure it using the screws that were removed.
Restore power to the microwave.
Oct 04, 2011 | Panasonic Microwave Ovens
FO ERROR ON OVEN
Seems F0 is a problem either with the control panel or with the key panel
Here is a test to find out whether its your control panel or control board:
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
You can go to this site to find replacements
Mar 14, 2008 | GE Profile JKP56 Electric Double Oven
What is Kenmore double oven error code "F7" mean?
For the F7 error code:
What color is your key panel? Black or White?
Aug 06, 2011 | Kenmore Ovens
Flashing signal.....F7
Possible problem with your key pad or control board.
(Gain access to control panel)
Feb 10, 2011 | GE Profile JKP56 Electric Double Oven
Control locked light stays on after load is finished.
The Control Lock is a safety feature that allows the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance. With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, or by leaning against the control panel and usually is not an indication of a washer malfunction.
If this is a Whirlpool Duet, the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem than a simple operator control issue (such as an operator console problem or main control board issue). If you need further assistance, please let me know. I hope this corrects the problem for you.
Mar 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does F7, an error signal, mean, and how to fix it?
F7 Means a stuck key on key pad or a short to the control panel
the control and key pad has to be gotten to threw the back of the stove make sure to unplug the stove first ...
Shorted key panel membrane switch; Check Electronic Range Control (ERC)
Nov 20, 2009 | GE Kitchen Ranges
GE JGBP85WEB5WW - F7 / E9 Error codes
Well first of all you determine if problem is with the Key Panel or Control by-
This error code means Function pad button stuck or Bad clock: Unstick button or Replace Electronic Range Control (ERC).
Post comments for more help or information........
Good Luck!!
Aug 31, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Jenn-Air JDS9860AAP Control Panel Problem
Control Panel
1. Remove power from unit.
2. Remove burner switch control knobs.
3. Open oven door and remove screws securing control
panel.
4. Remove screws located on the right and left sides of
the control panel.
5. Grasp control panel on the far left and right sides and
gently pull the control panel out and down.
NOTE: Gently pull control panel out and down.
6. Remove infinite switch control knobs, infinite
switches, indicator lights, rocker switches, and
electronic control/clock (as necessary) and transfer to
7. Reverse procedure to reinstall control panel.
Electronic Control
1. Remove control panel, see “Control Panel”
procedure, steps 1 through 5.
2. Remove screws securing electronic control bracket to
control panel.
3. Label and disconnect terminal wiring from electronic
control.
4. Reverse procedure to reinstall electronic control.try that
Jan 16, 2008 | Ovens
Control panel shows F7 and contantly alarming or beebing
F0 - F1 - F7 Stuck keypad may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
Oct 20, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
CONTROL PANEL
you are having a problem with your electronic control panel.to solve this problem you have to replace electronic control board and touchpad assembly.
Jun 17, 2007 | Kenmore 75002 / 75004 Gas Kitchen Range
Kitchen Ranges Logo
26 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
