Question about RCA P52937 52" Rear Projection Television
Home theater premiere tv will not power on
When turned on either by remote or by TV power switch a pop is heard but tv will not power up unplugging the tv for a few minutes does not reset the electronic protection circuit
4 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: RCA Home Theater Premiere 36" TV comes on automatically
Only two possible reasons I can think of for this--
ONE: you have looked in the customer menu and there is no item listed as Timer?
TWO: Does THIS SET HAVE THE GUIDE PLUS LOGO ON THE FRONT OF THE SET? IF IT HAS THE GUIDE PLUS--YOU WILL FIND IT IN THE MENU ALSO---
LET me know if it has the guide plus feature and I can tell you how to end the problem--most of these the set will come on at the same odd time and usually with volume up high.
SD TECH
Posted on Dec 26, 2009
  • 20 Answers
unplug the TV for 4 hrs. and let it reset to factory settings and then start from there scan for channel line up in the menu.
Posted on Jan 23, 2010
ladywinn
  • 5138 Answers
SOURCE: i heard a faint chirping sound almost like a the
Resolder on your Deflection board LL031 Coil then take a glue gun and Glue top of coil it is located on the right side of your FBT flybak Transfomer.
Posted on Jul 01, 2010
TV shuts off after 3 seconds
If the sound is still heard then the inverter board has failed and is triping the powersupply,if no sound the powersupply has failed.
Len..
Mar 29, 2014 | Panasonic VIERA TC-P50U50 50-Inch 1080p...
My television can't switch on
have you tried turning the tv off for 4 to 5 hours unplugging it
Jan 13, 2014 | LG 47LM6200 - 47" Class LED 3D Cinema HDTV...
Insignia akb36157101 does not power the tv any
Aim remote at the TV, hold down the TV Power button, and press the CH up button until the TV turns on/off. This cycles through 45 manufacturer codes.
Mar 13, 2010 | Insignia Digital-to-Analog Converter for...
Need Vizio TV code for my Samsung HT-X50 home theater remote!
Mine is 5. Press the TV button and let it go. When it quits glowing press the power button and hold it down. Then press a number (1-86) on the keypad while holding the power button down. If the TV turns off, you are done. Press the power button again and the tv should come on. If it does not work. Release the power button for a second and then repeat with a different number until the tv turns off.
Jul 05, 2009 | Samsung HT-Z310T Theater System
When I turn my unit on, it will turn itself off in a few second.
have you checked to see if any of your speakers are shorted out? the rt2870does have a self protection system in place such that if theres too much power being drawn from the system or if a short occurs it will shut off. or the switch that powers the sub may have gone bad so try disconnecting the sub and see if that helps. i have the same system and i had the same problem and i had to replace the onboard sub-woofer power switch.
Mar 15, 2009 | Audio Players & Recorders
Panasonic Home Theater won' play sound from TV
plug evey thing back how it was befor u unpluged the components to consolidate wall outputs.
May 11, 2008 | Panasonic Home Theater System System
Jan 30, 2008 | RCA P52937 52" Rear Projection Television
JVC AV-48WP30 48 in. Rear... Problem:
Take the batteries out of the remote control. Press every button 2 times. Then re-insert the batteries. While doing this unplug the TV and hold the power button down for 30 seconds. Then let go and leave the TV unplugged for 3 min. Then turn tv on do a channel scan and then try yhe remote.
Jan 08, 2008 | JVC AV-48WP30 48" Rear Projection...
Toshiba tz50v51 popping sound
Possible problems: * The TV set may be unplugged. * A fuse or circuit breaker may be blown or switched off. * The remote control unit (RCU) may be disabled. Solutions: * Make sure the TV/VCR are plugged in and the wall switch is on. * Check the fuse or circuit breaker. Test the outlet with a lamp. * Replace the RCU's batteries: if this fails exchange the unit.
Jan 18, 2006 | Toshiba TZ50V51 50" Rear Projection...
RCA P52937 52" Rear Projection Television Logo
16 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
