Question about Kodak Office Equipment & Supplies
Select projector class room
After removing Kodak 760H from storage. Everything works except the carousel will not turn freely when select switch held down. The locator lever moves back into the carousel.
    President:
  • Kodak Master
  • 412 Answers
The problem you describe is a timing issue. Because the 760H is so old (about 45 years old), parts availability may be slim to none.... You may be dollars ahead to buy a working projector off the internet.... Try: www.vinevalleyimaging.com
Good Luck !! Jim
Posted on Dec 09, 2014
SOURCE: Kodak Carousel 760H wont advance or reverse
Yeah. I like the $15 fix better. Go to Ebay and search for "Kodak Carousel Projector Advance Repair Kit". Before you purchase you can diagnose, and it comes with detailed instructions. The same guy also has a kits for other common problems, as well as the "tune up kit". Or you can buy the Solenoid Link, directly and try it without detailed instructions.
Posted on May 22, 2009
projdoc
  • 2237 Answers
SOURCE: My Kodak 760H Carousel projector does not advance
do you hear any sounds when you press the button? if not, the button may be malfunctioning. if it doesn't make a sound or movement in reverse either, there is a bad connection between the controls and the solenoids. if it does try to advance and not move the carousel, it's a mechanical problem in the mechanism. usually due to the grease getting sticky from heat and age. take it in for a good cleaning and an adjustment. there are a few cams in there that wear out after a while, too.
Posted on Nov 13, 2009
  • 412 Answers
SOURCE: My Kodak Carousel 760H projector will not advance
The problem is a plastic "link" that connects a solenoid to the advance mechanism. It gets brittle with age & cracks, yeilding the problem you have. You need to have the "link" replaced.
Posted on Nov 03, 2010
  • 412 Answers
SOURCE: Kodak Projector 760H. Carousel won't
Chances are that your projector has a broken solenoid "link". This "Link" connects the slide change solenoid and the slide change mechanism. Over time this part becomes brittle & cracks, rendering the slide change non-functional. A pretty easy fix for an authorized repair dealer.
  • 412 Answers
SOURCE: Kodak 750H and 760H neither will advance carolsel without manual
Both of these models were manufactured by KODAK between 1971 and 1981 (roughly). My guess is that they both have the same failure: The "link" that connects the cycle solenoid to the slide change mechanism is broken. This "link" is plastic, and gets brittle & cracks over time. While parts are still available, this repair is best done by a factory-trained tech with the service manuals.
Posted on Nov 04, 2010
Kodak MODEL 760h WILL NO LONGER project?
Make sure it is getting power if so, unplug from power, then replace the light bulb/reflector with a known good one.
May 08, 2014 | Kodak 760h Carousel Slide Projector...
Kodak carousel 760h projector
The auto-focus system in Kodak slide projectors is really an auto-measurement system: One set manually, the system is supposed to maintain that distance on all subsequent slides. Correct orientation of the slides is that they are all placed in the slide tray in the SAME direction (the matte side of the transparency facing toward the screen). The measurement is from the FRONT of the slide transparency to the BACK of the projection lens. REPAIR calibration of the system requires 2 special tools: a RANGE SLIDE and a TARGET SLIDE. These tool slides and the calibration procedure SHOULD be available from: www.micro-tools.com They purchased all remaining repair parts from Kodak when Kodak stopped supporting slide projectors. Good Luck !! Jim
Apr 30, 2014 | Office Equipment & Supplies
Yes, there is a fix. It's a pretty straight-forward adjustment. You can go to this web page: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-locale=en_US&pq-path=6499
The Service Manual there will detail the the adjustment.
Good Luck !! Jim
Mar 11, 2014 | Office Equipment & Supplies
The select bar on the projector is not working.
The Carousel 600 Projector is at least 45 years old!! Great to hear it still turns on!!
Because the 600 has no forward or reverse buttons, forward is accomplished by "tickling" (very lightly push) the Select bar. If you can cycle it forward and no Select, then you need to adjust the cycle solenoid to find the balance between forward and select. If you have NO forward, then chances are either the cycle solenoid is WAY out of adjustment, or the LINK between the CYCLE SOLENOID PLUNGER and the CYCLE LEVER is broken. You should still be able to order the LINK from: www.micro-tools.com
Good Luck !! Jim
May 19, 2013 | Kodak Carousel 600 Slide Projector
What is the correct carousel for a kodak 760 H projector?
A KODAK Carousel 760H is designed to be used with either KODAK 140 or KODAK 80 Slide Trays. The KODAK 80 Slide Tray has wider slide compartments, which tend to be more forgiving for older, slightly warped slides.
Oct 02, 2010 | Kodak Office Equipment & Supplies
My Kodak 760H will not stop once you switch the unit on. It just cycles through the whole carousel and will not pause long enough for you to view the slides. The remote will let you reverse it but it still...
The KODAK Carousel Slide Projector was manufactured from 1971 to 1981 (approximately).
The contact on the slide change mechanism is worn through. If you are lucky, a factory-trained repair dealer may be able to adjust it slightly so that it lasts a few more years.
Mar 23, 2010 | Kodak Office Equipment & Supplies
Bought a 760H to show some old sllides, but the tray does not advance. Is this something that can be fixed? Everything else works fine.
In a word - yes. Most anything on a Kodak Slide Projector can be fixed.
If your Carousel 760H will cycle in Reverse but not Forward, then it's an adjustment of the cycle solenoid. If the projector will not cycle slide forward ort reverse, then it is probably the cycle solenoid "Link". The "Link" connects the plunger of the cycle solenoid to the slide change mechanism. The good news: parts are available (www.micro-tools.com). You will need to seek out a factory-trained dealer to make either one of these repairs for you.
Aug 15, 2009 | Kodak Office Equipment & Supplies
The "arm" that ejects the slides has jamed on my Kodak projector.
the grease on the moving parts of the mechanism gets sticky with age. when the motor and cam stick, the select and index levers (which the cam moves) will stick. you'll need to remove the top and the whole mechanism and clean it out with wd40, dry it and regrease it. just remember what you removed so as to reinstall it properly.
Aug 09, 2009 | Kodak Office Equipment & Supplies
Kodak Carousel Projector 760 H, Carousel will not move
Given the age of your Carousel 760H, the most likely cause is a broken "Link". The "Link" connects the cycle solenoid plunger and the slide change mechanism. The "Link" is made of plastic and gets brittle & cracks over time, rendering slide change non-functional. Parts are still available (www.micro-tools.com), but this is an involved repair is best left to a factory trained technician with a service manual.
Apr 05, 2009 | Office Equipment & Supplies
You have jammed the slide change mechanism. Turn the projector off. Remove the tray using the emergency release slot in the center hub of the projector. Turn the projector on and cycle it a few times in reverse, then in forward. That usually clears a mechanism jam.
Nov 23, 2008 | Kodak Carousel 4600 Slide Projector
132 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
