Question about Oster 1.7 L Variable Temperature Electric Kettle
Not heating up
Lights come on kettle clicks but does not heat water
  • Reid Bollinger
    Reid Bollinger May 09, 2014
    I ran into the same problem where the unit clicks but does not heat water.
  • Reid Bollinger
    I found it to be a fault with the thermal cutoff safety device, which stops the unit from overheating if it's activated without water. The component is labeled AUPO BF-192 and is available for around $5.
In case you are still watching this issue for a solution - I'm afraid my assessment of the company troubleshooting support and of this particular issue is that we are out of luck.
I have the same problem. Have downloaded manuals - very little information except for use...ie, don't get them wet.
I have contacted the company - they asked me for the same information I gave them in the original troubleshooting request...
We bought a new one - fortunately on sale at Target. The blinking light is the normal indication - lack of heat and boiling is the problem.
Our new pot boils on both bases...old pot clicks and then just sits there with a blinking light - the light should blink until the temp is reached.
I intend to return the old pot to Target and move on....I suspect there is a burned out coil but, it is too hard to troubleshoot and won't be able to be fixed.
I suspect that a better (more expensive) pot might have more durable coils...but, we'll see how long the new one lasts.
Posted on Apr 27, 2014
My Cuisinart electric tea kettle won't boil water anymore.
It may be under warranty. Normally electric kettles are considered a disposable item, but your one is state of the art and expensive!
Contact their service department for advice. It has a 3 year warranty. The bad news is that it has 15 one star reviews! Not good.
CUISINART CANADA leader in culinary appliances professional quality...
Jan 09, 2016 | Cuisinart Kitchen Appliances - Others
Fugitronic automatic dispensoing hot water pot won't heat
The partial answer to your stated problem is that after 3-4 years of use it is possible that the heating element has worn out
Mar 08, 2013 | Fujitronic Automatic Dispensing Hot Water...
I have a Cuisinart CPK17 won't heat water and all the blue lights are flashing
I had the same issue with all lights blinking, but nothing else working (buttons would not respond or beep). I took the base off and used a small pair of pliers to bend the contact as Scott Cowen mentioned. Worked like a charm.
Jan 07, 2013 | Cuisinart CPK17 Electric Kettle
No light, no water heating
The heating element may have failed.
Sep 11, 2012 | Braun WK200 Electronic Water Kettle...
When I turn on to start heating the water ... it clicks on and off and now over time will not heat water. Power is coming to it... I have clean it in and underneath ... worked once and now again will...
Chances are the heating element has been fading until it can no longer operate. You can try to have the heating element replaced or replace the unit.
Nov 09, 2009 | Bravetti EK119H Electric Kettle
Red light's on... but no hot water!
HI,
OK, inside the unit there are three items, the heating element, thermostat, and thermal fuse.What has happened is the element got too hot and the thermal fuse opened.There is no reset button.In some cases you may run across a defective heating element or thermostat but its not common.The fix would probably be replacement of the thermostat and thermal fuse.For this, you would have to contact a small appliance repair center in your area.
Goodluck,
Please don't forget to rate the solution
Apr 05, 2008 | Braun WK600 Cordless Electric Kettle
Red light flickers, goes off, no heat
I had a similar failure with my Braun WK600. Switch it on and the lights flicker and go out before it boils. Took it apart (Tamper Proof TORX, available from Snap-On, Canadian Tire, probably most auto parts places that also sell tools). The On-Off switch has a mechanical lock out for the lid being open and also for when it is not mounted on the base. The kettle also has three bi-metallic temperature switches. One shuts off the kettle after it has boiled long enough. The other two sit up against the element assembly adjacent to each end of the heating element.They protect against boiling an empty kettle by sensing the higher element temperture when there is no water to conduct away the heat. In the case where the lights flicker and go out, but the switch stays 'On' these are the likely culprit.
In my kettle the contacts did not line up correctly. Instead of making good contact they were only partially overlapping like a couple of the olympic rings or a couple of rings from the Audi logo. This resulted in a localized increased resistance and high heat in one of the contact holders which eventually melted the surrounding plastic. At that point the wires going to the element behaved a bit like springs which forced the contact holder further out of alignment until it all became hot enough to trigger the thermal switch.
I fixed it by bending the contact holder, which is fused into the now hardened plastic, to the optimal position and hopefully it will not generate enough heat to remelt the plastic or trip the thermal switch.
I have boiled a couple of kettleful's; so far so good!
Oh, and if you take your kettle apart and your house burns down it is not my fault.
Nov 22, 2007 | Braun WK600 Cordless Electric Kettle
Oster 1.7 L Variable Temperature Electric Kettle Logo
627 people viewed this question
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Ben Eng
Level 1 Expert
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
