Question about Hasbro Star Wars R2 D2 Interactive Astromech Droid
How to replace the lights
One of the lights went out and seems to have put the whole strand on the fritz, im just not sure how to go about removing the droid and replacing the light
Hi I have a 2001 Chev Cavalier LS 2.2 w/4spd and trac and abs so here is my series of events it all started in august of this year went in for trans flush had to take it in three times to get right not...
can't help much- does sound familiar, but can't quite pin it. you took the battery out & replaced it. may need software reinstalled, or possibly upgraded. make sure your maf is functioning properly, and well connected. how about your O2 sensor(s)? could be electronic problem with tranny- intermittent, of course!! don't you love those imps? good luck!!
Nov 04, 2013 | 1997 Chevrolet Cavalier
I have a 2002 FXST H-D, I replaced the battery about 2 weeks ago because of starting problems. Today I rode to work and it was raining off and on, (not sure if that matters) but went to start the bike when...
Make sure you have not knocked loose the alternator cable. Usually close to the oil filter. Sometimes when removing the oil filter it will come loose and you won't be charging your battery while you ride.
Dec 17, 2012 | 2002 Harley Davidson FXST Softail Standard
My light went out on my Dash Board for my A.C so i cant see what temperature im putting it on
To my knowledge the lights inside the ac control panel are not replacable still. It comes down to willingness to pay to replace the whole panel or deal with the light being out. I had that issue on my 02 dodge ram and i had to replace the whole unit because the lights inside it are led
Jul 22, 2012 | 2004 Chrysler Pacifica
Breeze's brake light went out. changed bulb, now whole tail light won't work.
sounds like you put the wrong bulb in, that will make it blink fast. re check
Apr 18, 2009 | Plymouth Breeze Cars & Trucks
Got in my jeep turned the key and nothing! it will not start.
remove the small wire going to starter motor solonoid and put a test light on it --if it doesnt light up when key is turned then work your way back till you find the fault,relay? contact switch on ignition??
Apr 11, 2009 | 1995 Jeep Grand Cherokee
REPLACE HEADLIGHT ASSEMBLY IN 2000 LINCOLN TOWNCAR
Open the hood and make sure the car and the lights are off.
Remove the plastic protective cover.There are 3 knobs,turn halfway and pull.Put aside and out of the way.
Remove the three pins that are holding the light assembly in place.These are flat rods with a little bend at the end.
Twist and un-plug the lights,now you can remove the whole lens.
The light bulbs can also be removed and replaced from this point.
Make sure all the bulbs are working before you put it back together.
Mar 13, 2009 | 2000 Lincoln Town Car
Engein stopped running.
change the oil sending unit.
Oct 12, 2008 | 2000 Ford Explorer
Mitsu medallion hdtv ws-65613
Hi Mikehill278,
No the capacitors should be fine 35v 1000uf are actually what I was told to put in and I just put them in and the green light went off and tv started up. However, now I have no video so not sure if I jarred something lose in the whole process. Anyhow, hope this helps.
Oct 01, 2008 | Mitsubishi WS-65613 65" Rear Projection...
Color Problem
In rare instances it is sometimes the 15 pin connector that connects on the computer end. Could be at the monitor end of the same cord, if it is a connector and not hard wired to the inside. Check both possible sides for bent pins.
I once went through an extension cable and had to remove it as it was bad connections and I'd have constant color changes drifting in and out. Sorry, but most likely it is just a cheap monitor on the fritz.
Sep 07, 2007 | X2Gen MG19MY 19" LCD Monitor
Hasbro Star Wars R2 D2 Interactive Astromech Droid Logo
18 people viewed this question
Top Hasbro Toys Experts
thegtw
Spidey28
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
