Question about Honeywell V800A1070 24 Vac Standing Pilot Gas Valve
Adjust pilot light v800a 1070
Adjustment of pilot light
    New Friend:
  • 45 Answers
First try disasembling the pilot orfice and clean with blast of carb or brake cleaner( out doors only away from flame).. the hole is very small and gets plugged by rust in the pipe system..if overall pressure is low there is a cap screw to remove and tightening the regulator screw down increases the pressure..this should be done by a professional with a pressure gauge on the manafold..
Posted on Jan 03, 2015
I have a dyna glow 18000 btu btrand new the pilot just flickers on and off won't light is it because there is too much oxygen if need adjust where is the adjustment screw at
Flickers points to lack of air you may need to clean pilot so its strong and blue . Any adjustment would be near where the pilot supply goes in the the gas valve.
Jan 20, 2018 | Heating & Cooling
How do I find adjustment screw for pilot light on 1998 white rodgers hot water gas 6 gallong
most pilot's are not adjustable. if it is not staying lit, replace the thermocoupler.
Jan 06, 2015 | Water Water Heaters
How to adjust brightness of monitor on on HP Envy TouchSmart 23 All-In-One?
Try using Fn keys to adjust, otherwise check the setting and control panel applications. Could be something wrong with your power plans as well.
May 14, 2014 | HP Envy 23-1070 All-In-One Desktop PC with...
Pilot light flame too loeeds adjustment
Adjust the pilot flame height using the adjustment screw for each burner.
Mar 12, 2014 | Magic Chef Ovens
Surburban sw6p pilot adjustment
if good pressure from regulator and clean assembly and burn tube shouldn't have to adjust check pressure from regulator
Feb 09, 2014 | SUBURBAN MANUFACTURING C Surburban Water...
How to adjust pilot lite on a furnace
Select thermostat to off. Take front upper panel off of furnace. Looking at gas valve you should see a flat head or straight slot screw. This is the cap to access the adjustment. Look at the body of the gas valve real close. You may need to put on your glasses or use magnifying glass. It should say pilot in very small raised letters. Remove the cap. Look down into access hole and you will see the adjustment screw. It is a nylon screw so be careful not to strip it out. Place the correct screw driver, should be a small phillips or straight head. Turn gas valve to pilot and depress. Light pilot. While holding down, adjust nylon screw clockwise until flame envelopes 3/8 to 1/2 inch around thermocouple. Replace cap. Select heat and verify pilot stays lit. If the flame doesn't stay lit most likely your thermocouple is defective. You can purchase at your local hardware or Home Depot. Length doesn't matter.The thermocouple is heated and sends a DC signal back to the gas valve. There is another screw cap on the gas valve that adjusts gas pressure. Do not try to adjust the gas pressure to the gas valve because you need a special instrument (manometer) to adjust pressure. This device measures the water colume of the gas. A qualified technician would adjust this to 3.5" WC. for natural gas or 11" for propane.
Dec 09, 2013 | GPS
Adjust pilot light on hot water heater
On most water heaters there is no adjustment to pilot light. About the best you can do is clean pilot and burner. If you are having trouble keeping pilot light lit then I would replace the termocouple.
Nov 16, 2010 | Water Heaters
Pilot light
On the gas valve there is an adjustment for the pilot it usually is a machine head type screw if you remove it there is a limit adjustment for the pilot under that. It will not be the flat cap type screw and it will not be a black plastic inner screw to adjust, it should be a metal brass screw you adjust. Not trying to throw to much info at you just making sure you get the right screw to adjust the pilot. The flat metal cap cover screw with the black plastic screw underneath is the pressure regulation adjustment, so it is critical not to touch it.
Hope this helps You
please rate me
Jul 23, 2008 | Imperial IFS40 Deep Fryer
Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Aug 14, 2007 | Tappan TGF363 Gas Kitchen Range
Honeywell V800A1070 24 Vac Standing Pilot Gas Valve Logo
530 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
