Question about netTALK DUO Wi-Fi VOIP Internet Phone Device With 12 Months Service
Can not make or recieve calls
Can not make or receive calls
I can receive calls but can't call out
Has your service provider changed your tariff so you can receive calls but not make them? Check with them!
Nov 02, 2014 | Clarity D613 Cordless Phone
International dialing code don't display when receiving calls so i won't know who calling
The calling code is only for out call only.
the country you recieve the call has its oun code also.
so when you recieve a call you get no country code at all because your country code could be different.
example is to call philippines you use code 63 to call out,but someone in philippines need to enter011to call USA country code is for outcalls only,Gary
Oct 26, 2013 | Pantech Cell Phones
Will not call or recieve calls has new battery and sims, everything works but can't make calls or recieve calls.
If the phone works fine as you said but cannot make calls or receive, this could be a network problem, you will need to contact your network service provider of the sim you are using, it could be that they are yet to activate the sim, giving them call to explain the problem will help to activate the sim. Try use a friend phone to call the customer care line to give the details of the problem, by so doing, they will help activate your sim so that you can make calls and receive calls.
Jul 27, 2011 | Samsung Rugby SGH-a837 Cell Phone
Nokia E75 Call not Allowed Cannot make or receive calls. Do receive sms and emails.
my phone is nokia e75 , I cant make or recieve cals but I can recieve and make emails , sm, netwoking please help
Sep 10, 2010 | Nokia E75 Cell Phone
Dialled calls,missed calls and recieved calls
hi,
in my phone dialed, received and missed call data are not saved. all data vanished and it shows empty always
Jul 09, 2010 | Samsung Cell Phones
My directv d12-300 receiver won't take the software download why?
Because the reciever has a internal issue. you will have to call directv and get a tech to bring a new one. to redo, turn of reciever and when you see the blue light power press 02468/
Jul 18, 2009 | RCA DRD430RG DirecTV DTV Receiver
Direc TV remote won't work Receiver
call directv and they will walk ya thru reporgramming remote for reciever. or goto menu, setup, remote, then follow on screen instructions. i cant give u the exact instructions cause every reciever is a bit different and its different if one remote operates two directv recievers. ( like a bar would do to operate two tvs with one remote)
Jun 12, 2009 | Directv Universal Remote
I can not recieve messages or phone calls
Double check your phone number by calling another mobile and confirming what number comes up on their phone (my sister recently discovered she'd been giving friends the wrong and wondering why they couldn't call her...)!
Then try calling back using the "received calls" list from their phone. If it doesn't work, you'll need to contact your service provider as their is an incorrect setting in their network.
Feb 10, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Nextel i850 can't receive calls
  • may be the walkie talkie can recieve signals only to an certain distance,so it may be due to the signal problem........
  • if the reciever is beyond the permitted distance it loose its frequency...........
  • or else the person who is calling walkie talkie might not hav signal in that area.....
  • and if the walkie talkie does not recieve any signal then the receiver component present inside the walkie talkie might be damaged.........
  • and if it does not reply to an signal transmitter might be damaged..........
  • i hope my answer would be sufficient for u.....thank u......
Sep 10, 2008 | Motorola Mobility i850 Cellular Phone
Unable to make and recieve calls
I flashed and flexed the set but to no avail, tried a software update but no update was available from motorola. I then went to the Security settings of the set and restricted all outgoing calls and restricted all incoming calls except the phonebook entries. Then I dialed my mobile using a landline which was on my phonebook and my phone started recieving the calls, then after that I allowed all incoming and outgoing calls. This solved the problem. I believe it is sheer luck because I tried that step earlier on the same day but it gave no result.
Jul 21, 2008 | Motorola Mobility L6 Cellular Phone
netTALK DUO Wi-Fi VOIP Internet Phone Device With 12 Months Service Logo
Top netTALK Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a netTALK Cell Phone Expert? Answer questions, earn points and help others
