Question about NetGear WN2000RPT Repeater
Unable to connect
I am having a hard time getting my WND2000RPT to work.... What do i need to do?
My Acer Travelmate 4100 is unable to turn on. The power light is on and fan is running, however, the screen is completely black. I have tried the remove batter and AC, 30sec power reset, replug format...
If nothing is happening with a good battery or a good power adapter you have a serious issue. Could be bad mo bo, corrupt cmos, bad hard drive, bad peripheral, .
Remove drive and plug into another known working computer as slave and see if it works and perform diagnostics on it. If it checks out at least you have your files and data . But the rest of the unit ................................
Sep 22, 2017 | Acer TravelMate 4100 Notebook
Some time unable to get the display and some times unable to detect the hard disk and cd drives
First check the connection whether it is loose or not? If not Better change your Motherboard.
Nov 30, 2010 | Mercury P4VM800M7 Motherboard
I have an acer laptop I've been getting the bsod saying it's an unmountable Boot volume when I try to go in safe mode it doesn't allow me to and when I go to the repair option as windows recommends it just...
The easiest way to fix unmountable boot volume is to stick the hard drive into another machine and then run a chkdsk on that hard drive eg. if the hard drive is e: then goto Run on the start menu, type CMD, click OK then type chkdsk e: /f /r Once this is done stick the hard drive back in your machine. I suggest you do a good virus and spyware scan or it could be from a power surge or improper shut down. Good Luck
Nov 12, 2010 | Computers & Internet
I am having difficulties connecting
first of all you need to reset your router.
what internet connection do you have like dsl , dailup
do u have static ip for your internet
Jun 16, 2010 | Linksys Wireless-G Broadband Router
I plug in my free agent go external hard drive to my pc but it wont even show that is connected in my drives... it works fine on my laptop all of the software is on the drive but I am unable to download it...
Sounds like either a Bios problem, or just needs drivers installed in the non working problem.
You may have a USB conflict.
Try to remove some items in your hardware manager under windows, then let windows re ad them, that may fix your problem.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Nov 13, 2009 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
I have a Compaq Presario 2715US. Started having
The problem maybe a loose electrical connection with the RAM modules and hard disk. Re-seat the RAM modules and the hard disk.
If the problem persists then the hard disk maybe faulty.
To test the hard disk, remove the hard disk and connect it to an USB hard drive adapter and connect it to a working computer's USB port. If this computer has trouble seeing it as an external hard drive and unable to open the folders and files then the hard disk is faulty.
Then the hard disk needs to be replaced in the Compaq and Windows XP needs to installed on the new hard drive and the device drivers and programs.
Oct 12, 2009 | Compaq Presario 2715US Notebook
External Hard Disk Unable to Explore
hdd regenerator 1.61 is not a cheap program but I have used it in a similar situation and it worked extremely well
Mar 28, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
SimpleTech Signature Mini (320GB) unable to find on my laptop
if you hear a constant clicking return the drive it is faulty.
Mar 27, 2009 | SimpleTech Signature Mini 320GB External...
Unable to open hard top on slk230 1999 mercedes benz
another suggestion is that you need to have the code re-entered for the hardtop. I just had mine repaired due to a busted hydrolic hose, and the mechanic had a hard time getting it to work properly and ended up having to re-enter the codes.
Jul 25, 2008 | 1998 Mercedes-Benz SLK
NetGear WN2000RPT Repeater Logo
81 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
