Question about ZT Group CISNET A7022 PC Desktop
Attila egfffbff fgfgu guuz 15 42
Tefal clipso not pressurizing
Attila, it could be the safety valve. Both the gasket and the safety valve have parts that are rubber or silicone. You'll want to check both of these. In what general area is pressure leaking?
Also a good resource (with forums):
http://www.hippressurecooking.com
Dec 06, 2013 | Tefal By Jamie Oliver Clipso P4110769...
Require driver for toshiba nb500 that can be used on windows xp
The driver for your Webcam Model NB500 can be get to cnet.com. Type on the search area on the model of your webcam NB500 driver. Download the driver and run it.
Sep 20, 2011 | Computers & Internet
My L1930B display darkens right after switching it on. The image of the computer appears only for a millisec. If I keep trying switching on and off, it begins working, but usually it doesn't. What could be...
If not a bad kettle lead or loose connection at the monitor it could be:
Failing inverter, also maybe powerboard capacitors leaking or not holding charge. flicking the power switch will cause it to fail more quickly, repair or replacement I'm afraid
Jan 10, 2011 | LG L1930B 19" LCD Monitor
Hello, I have a bottom freezer refrigerater that keeps freezing up in the vent hole rendering the fridge less than ideal temperature for keeping food at a safe temperature. How cane I stop this freez...
There MUST be room in your freezer for air to circulate. Check the arrangement of your frozen foods to be certain they are not blocking any vents. If your freezer is over-filled, you might want to discard some of the older packages to allow air flow.If this does not correct the situation, you'll probably need to have a service person take a look at it.
Nov 04, 2010 | Kenmore Refrigerators
Sounblaster ct 4170 for xp driver help
http://www.bioticaindia.com/sound-blaster-ct4170.html
Sep 02, 2009 | Creative Labs CT4170 Sound Card
Connecting to pc message
connect the mini usb calbe to Camera only. Camera will working like without cable. Go to setup menu and Change USB setting to P, PTP. the unplug the miniusb and hopefully camera will work as it one.
It worked for me :)
Attila
Aug 31, 2009 | Nikon D40x Digital Camera
Video playback problems
try install the Klite codecs!!!
Feb 07, 2009 | Kodak EasyShare Z710 Digital Camera
My Nikon D40 is frozen on the screen "Connecting to PC". I have left the battery out for months, tried resetting it with the reset button, tried reformatting the SD Card, etc. When I turn it on now, it...
connect the mini usb calbe to Camera only. Camera will working like used to be without cable. Go to setup menu and Change USB setting to P, PTP. then unplug the miniusb and hopefully camera will work as it once was.
It worked for me :)
Attila
Dec 27, 2008 | Nikon D40x Digital Camera
Broken 22 Pin,sync,charge,connector
Here's a solution for the broken socket on Mio 168 and Medion Micromaxx mdppc150 clones. Cheers
Mar 17, 2008 | Mitac Mio 168 Pocket PC
ZT Group CISNET A7022 PC Desktop Logo
Top ZT Group Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Kyocera HP Expert
Are you a ZT Group Computer and Internet Expert? Answer questions, earn points and help others
