Question about Kenmore 15516 Mechanical Sewing Machine
Cant get model 38515516000 machine to thread
Cant thread it
How to thread a Empisal overlocker.. model 760C
Perhaps the manual would help:
Empisal Overlocker 760C Empisal Sewing Machines
On most machines, it is important to ALWAYS raise the presser foot when threading the machine (although the instruction manual says to raise the presser foot only to pull the thread tail under it). Be sure to give the thread an extra little tug when going through the tension disk to seat it properly. Be sure to thread in the order as specified (Upper looper, Lower looper, Right needle, Left Needle). If the machine messes up, it is usually a best policy to remove all the thread and rethread from the beginning. Threading out of order will almost guarantee failure!!!
Jul 20, 2016 | Sewing Machines
I cant feed the overlocker.. so it dont want to work
Best to refer to the owner's manual. You can search the internet for the Make + Model + the word "Manual" and you may find a free download.
ALWAYS raise the presser foot while threading the machine.
Be sure to thread each in the order specified in the manual (usually, Upper Looper, Lower Looper, then the needles). Threading in the incorrect order will guarantee failure!
If a thread breaks or the machine messes up, it's usually best to remove All the threads and rethread from the beginning.
To start out, it helps to use a combination of different color threads.
Set the tensions to the midway point (the standard for basic overlocking).
I have a Seam Master sewing machine Model695 Serial NoD0200008 i cant find my book
Search the internet for:
Or search YouTube for videos of threading and operation of sewing machine (you can look for your specific model, but may find a model similar to yours). Also search for threading diagram.
Jan 26, 2016 | Sewing Machines
Thread bunching up on the bottom
try changing the needle
rethread the machine top & bobbin
make sure the top thread has not come off the thread take up lever
clean under the needle plate & in the bobbin area for lint or loose
thread
Aug 23, 2012 | Sewing Machines
How do you reassemble a shuttle hook? Send picture
Page 70 in the manual. You can get the manual at the below site.
http://www.managemylife.com/mmh/owner_manuals/9123/KENMORE-Mechanical-Sewing-L0306419?brand_name_search=38515516000+KENMORE
Nov 13, 2010 | Kenmore 15516 Mechanical Sewing Machine
Cant find a manual or thread machine properly.
Submit a new question providing details on manufacturer and exact model, click here to submit a new query.
Nov 15, 2008 | Sewing Machines
I have an old Singer Sewing Machine Model 786, there seems to be a problems with cobbling underneath, causing looping on the underside I presume its the bobbin but have been unable to fix, I do not have...
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Aug 09, 2008 | Singer 7462 Mechanical Sewing Machine
Bobbins
Have a look at this website on the threading page, if your machine is not listed look at some of the other Kenmore machines and you will get the idea of how to remove the bobbin case. Basically you will find a small latch across the front of the bobbin case, pull the latch away from the case and hey presto.
www.sewusa.com
Apr 23, 2008 | Sewing Machines
Kenmore 15516 Mechanical Sewing Machine Logo
24 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
