Question about ASUS Computers & Internet
Laptop should fan start when t is first booted
K52jt
The screen remains black, laptop won't boot, fan makes a low noise
try test an external screen to the computer, if you got it working, you have a broken backlight
Dec 29, 2013 | Computers & Internet
Fan on Dell M5030 Starts on startup and then shuts down but computer continues to boot
Lots of fans are variable speed. Meaning they spin faster when the computer is hot and slow down when not. It's most likely spinning down. If the fan was bad the computer will either shutdown or generate an error during BIOS and halt the boot process.
Jan 11, 2013 | Dell Inspiron M5030 Laptop
I cannot turn on wireless for asus k52j, Fn and F2 key does not work
Usually the people might have problem related to asus laptop because of wireless driver. so you need to unisntall the wireless driver and reinstall it. your wifi will start working fine. hope this will help you better. for more information you can visit : Tech Support For Asus
Apr 13, 2012 | ASUS K52JT-XT1 Laptop Computer - Intel...
White stripe on screen cannot get it off. Approximately one inch wide from top to bottom of screen. Curser will go under it and it will not phase the strip.
This is a problem with the LCD panel itself. The controller for the panel has failed. You will need to contact Asus for a replacement part if it is still under warranty.
Jul 06, 2011 | ASUS K52JT-XT1 Laptop Computer - Intel...
Restore in factory settings
how do i reset my K52Jt Asus laptop to factory setting
Jul 01, 2011 | ASUS K52JT-XT1 Laptop Computer - Intel...
Only the fan turns on when I try to start the laptop .
This is a sign of problems with the motherboard. If there is no boot, fan comes on and no screen, the motherboard is the likely culprit. Time for a computer repair shop.
Mar 21, 2010 | Computers & Internet
My ACER 5100-4720 boots up with a black screen and after about 15 minutes it loads Windows Vista, but it is very sluggish, then it acts like it gets up to speed and still runs sluggish. I have 1GB DDR2,...
The first thing I would check is that the cpu fan is working. You should be able to see the fan come on from the bottom of the laptop. Sometimes the fans can stick from dust and dirt. Then the cpu will get very hot and cause the computer to slow way down. Try using a can of compressed air on the fan and see if it starts working. If the fan is working ok then you might have some type of virus or corrupted installation causing the computer to slow way down. You could try pressing F8 right before windows starts to load. This will bring up a boot menu. Then try booting the computer in safe mode with networking and see if it boots up fairly quickly. Once it boots up in safe mode run your virus scanning software to see if there are any viruses on your computer.
Nov 19, 2009 | Acer Aspire 5500 5570-2609 Laptop
Compaq presario starts but will not boot up
Check whether your CPU fan is working. It could be due to Fan malfunction of the cabinet also. Seek technician's help, if not resolved
Aug 21, 2009 | HP 435768-001 - Compaq Presario C300...
Itronix VR-1 Go Book Fan Failure message
After bios upgrade had same problem. DISCONNECT AC POWER PULLED BATTERY FOR AT LEAST 5 MINUTES THEN REATTACHED BATTERY AND FAN WORKED ON NEXT RESTART. Also make sure boot menu ( tap F12 at start-up) is set to boot from Hard Drive. I also started on battery power with no ac adapter.
Apr 17, 2009 | Computers & Internet
On my laptop the vent fan starts then stop and the power goes out
These machines have a terrible overheating problem! You will have to clean the fan opening and, put sylicon grease on the heat pipe and, heatsink that covers the cpu
Apr 04, 2009 | HP Pavilion dv9000z Notebook
Computers & Internet Logo
12 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
