Question about HP EliteBook 2760p - Core i7 - 12.1" TFT
Volume having trouble with volume. adjust it and still can't get any sound
I can not find out how to adjust sound on my RCA tablet. It is extremely loud and I can not turn it down. Where do I go for this adjustment?
Hi click on tools or settings icon it should open a page with all the settings look for sound click it on & adjust volume ... Cheers
Dec 18, 2016 | Tablets & eReaders
The sound on this tablet virtually non existent
Hi u don't mention make of tablet check the sound settings tap on tools or settings scroll down to SOUNDS & tap on volume,,::::: adjust settings good luck
Jun 18, 2016 | Tablets & eReaders
Sound in speakers is lousy
Tablets are notorious for bad sound. I use a volume adjuster app to boost sound and use earphones.
Apr 02, 2016 | Trio 1 - MACHSPEED -STEALTHG210.1 10.1"...
Volume is all the way up. Why is there no sound, not even the clicking sound while typing?
hii click on settings or tools on youre icon page & go to sounds to adjust youre settings.good luck
Jul 13, 2015 | Irulu 7" Google Android 4.0 Capacitive...
I do not have a volume button to the side of my tablet what else to press to go down the screen
If your tablet is similar to Amazon's Kindle Fire, swipe down from the top, Look for the volume icon touch screen and you can adjust from little sound to ear shattering sound. Good luck, Lora
Jan 02, 2015 | Tablets & eReaders
Low sound can hardly hear it even tho the sound is turned high
Sometimes the app you're using has it's own sound control that overrides the device sound setting. Look in the app for sound settings, eg audiobooks apps often have a separate setting for volume and this is the one that you need to adjust.
Jan 01, 2015 | Tablets & eReaders
How do I shut off volume in an app.
In many applications once the app is open you can press the volume up / down buttons to adjust the volume in that application. Many times however the volume will effect the whole device and not just that app. so notification sounds etc will also be lower.
Nov 17, 2014 | Amazon Kindle Fire HD
What happen to sound on kocaso tablet
Check you have not accidently turned down the volume.
Adjust the volume by pressing volume +.
Apr 27, 2014 | Kocaso Tablets & eReaders
My Bluetooth seems paired but no sound
It helps to state what iOS you are running for these kinds of problems. Depending on what app you are trying to use, you sometimes have to literally tell the iPad to choose your earpiece for sound for that particular app. Also be sure your bluetooth volume is up. This is independent of your main volume and can be adjusted only when connected. Simply use the volume adjustment on the side of the iPad. Some earpieces have their own volume control as well. Be sure to tap that up a few times as well.
Jan 27, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Where is volume control on dell laptop
Hi there! this might work :)
1.Click once on the speaker icon in the lower right corner of the laptop screen on the task bar to open the volume control.
2.Click and hold the slider control with the left mouse button or the left button on the touch pad, then drag the control higher to increase the volume on the built-in speakers.
3.Click the "Start" or Microsoft flag button in the lower left corner to access the Dell's Control Panel. Click twice on the Control Panel.
4.Click "Hardware and Sound" then click "Adjust System Volume" under the "Sound" listings.
5.Click and drag the slider control to adjust the sound level, then click the "X" box in the upper right corner to close the application.
Sep 30, 2011 | Dell Tablets & eReaders
HP EliteBook 2760p - Core i7 - 12.1" TFT Logo
11 people viewed this question
Top HP Tablets & eReaders Experts
Anthony Pattay
Level 1 Expert
Lawrence Oravetz
Are you a HP Tablet and eReader Expert? Answer questions, earn points and help others
