Question about Uniden BC72XLT Handheld Scanner
Scanner won't turn on when button is pressed
Scanner won't turn on after I replaced the batteries
Fully charged. Why doesn't it turn on?
Ruby, try pressing and holding on button or you will have to reset.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Reset Kindle Fire When it Won Turn on or Charge
My kindle won turn on
My kindle won turn on Is it the battery Kindle Fire HD
Amazon Kindle Won Charge Quick Fixes
Mar 12, 2016 | Amazon Kindle Fire HD
Water from a water bottle spilled all over my TI-84 Calculator. I dried it the best I could and replaced the batteries after drying them but none of the buttons work and it won't turn or. And way I can...
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
I also hope you let the calculator dry out thoroughly before replacing the batteries.
Sep 03, 2013 | Office Equipment & Supplies
Samsung sgh T669 won't turn on
Dear Brother;
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Dec 06, 2012 | Samsung Gravity SGH-T459 Cell Phone
Nook won't turn on
5.Wait 10 seconds.
Step
Thanks
Oct 14, 2012 | Barnes & Noble Nook Simple Touch eBook...
On the wii fit board I press power button it flashes but won't stay on
Have you replaced the batteries and you also need to press the SYNC button inside the battery cover underneath the wii board and the SYNC button on the Wii console at the same time.
Apr 28, 2012 | Nintendo Video Game Consoles & Games
Polaroid A500 digital camera pressed ON button, nothing happened with new AA batteries and SD card
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Nov 25, 2011 | Polaroid Cameras
How do I get it off manual scan uniden bc72xlt when i turn it on it won't scan. thanks need help.
these scanners are a little hard to operate i have one of these it took me a while...Ok its because you have it on hold.when you turn your scanner on press your scan button.and your scanner should start scanning...
Jul 09, 2011 | Uniden BC72XLT Handheld Scanner
The scanner won't move. I tried the lock button and it is not locked. Light comes on and paper goes through but scanner doesn't move.
if the scanner is not locked, you can try pressing #*C* then enter 14 and press start, if it is not resolving your problem you need to replace the carriage motor mcu pwb and the power supply pwb respectively.
May 18, 2011 | Sharp AL 1631 Copier
Pn-20 fails to start
Here's delorme's forum page on reset options and firmware updates if you so choose:
http://forum.delorme.com/viewtopic.php?t=10995
Mar 15, 2009 | DeLorme Earthmate GPS PN-20 for PC, Sun
Uniden BC72XLT Handheld Scanner Logo
47 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
