Question about Sony DVP-FX810 Portable DVD Player
No disc message
All discs will cause the same message
I consistantly get an update message after trying to record disc to disc as little as one track why?
That is best discussed with the Philips support people as there could be a reset procedure. I have never heard of this but you may have caused the unit to enter a different mode by doing an overburn attempt.
Dec 19, 2012 | Philips CDR775 2-Disc CD Recorder
Tip
How to solve the Wii console problem : "Unable to read the disc" or "Disc could...
If you are getting one of the above error messages:
  • This message can display if you eject a disc during game play. If this is when the message displayed, make sure that you return to the Wii Menu before changing discs if you wish to play a different game.
  • If your Wii console is laying flat, it may be positioned upside down. Ensure that is positioned right-side up: the game disc slot should be above all three buttons and the SD Card slot.
    • If your console is placed vertically, the disc label will face to the right.
    • If your console is placed horizontally, the disc label will face upwards
  • Check our list of specific game issues to see if there is a known issue with that particular title.
  • If you know you are inserting the Game Disc correctly, but are still have the same problem with only one game (or if you only have one game), try cleaning the Game Disc by following the disc cleaning procedures (click here).
If the above information did not resolve the issue or it is happening with most or all of your games, a repair is necessary. Please note: So that our technicians are able to duplicate the issue, please include at least one sample game disc that causes this message to appear when played. Click here to set up a repair.
on Aug 10, 2010 | Video Game Consoles & Games
Tip
When you try to play a DVD game on Xbox 360 it tries to play as a movie?
c on your Xbox 360 console, you may receive an error message. This article presents step-by-step guidance to help you determine whether your disc is playable.
SYMPTOMS When you try to play a disc, you may receive the following error message: Can’t read this DVD.
CAUSE The DVD or game disc may be dirty or damaged. Because the console cannot read the disc well, it may even mistake a game disc for a DVD and report this error. If this problem occurs with multiple discs, even clean and undamaged discs, there may be a problem with your Xbox 360 console.
Note If you receive a different error message, such as one of the following messages, the problem is a different problem:
Error message 1 Can't play DVD. Wrong region code. Error message 2 Can’t play DVD. Family settings restrict playback of this DVD. If you receive one of these error messages, see the corresponding Knowledge Base article: 907620 While attempting to play a standard DVD movie using your Xbox 360 console, you receive the error message: "Can't play DVD. Wrong region code" 908645 While attempting to play a DVD movie using your Xbox 360 console, you receive the error message: "Can’t play DVD. Family settings restrict playback of this DVD"
THINGS TO TRY Here are some things that you can do to try to fix the problem or to determine what caused it.
Determine whether the disc is dirty or damaged Discs that are smudged, scratched, or otherwise damaged cannot be read by the Xbox 360 console. You will want to examine the disc to see whether it has smudges, scratches, or other damage. To do this, follow these steps: 1. Examine the disc for dirt or damage: a. Pick up the disc by its edges. Do not touch the top or bottom surface. b. Examine the shiny side of the disc to make sure that the disc is clean and has no damage.
NoteScratches that follow the curve of the disc are very damaging and prevent a disc from being read. If your disc has even one of these kinds of scratches, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 2. If the disc is dirty, clean the disc by hand: • Use a soft, clean, dry, chemical-free cloth to clean the disc. • Lightly wipe from the center of the disc outward. 3. After you clean the disc, try to load it in the Xbox 360 console. If the disc still will not load or you receive the same error message, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 4. If the disc is damaged, do one of the following: • Because DVD discs are not game discs and the disc was damaged because of misuse of some type, such as not storing the disc in its case, the only thing that you can do is buy a new one. • If you feel that the disc was damaged by the Xbox 360 console in some way, please contact Xbox Customer Support. To do this, please visit the following Microsoft Web site: http://www.xbox.com/support/contact
on Feb 18, 2010 | Video Game Consoles & Games
WII unit will not read disk when put in. Screen says there is an error and to remove disk but gives no other directions. What may the problem be?
    "Unable to read the disc" or "Disc could not be read" Messages
Aug 23, 2011 | Nintendo Wii Console
Unable to read the disc game
Aug 20, 2011 | Nintendo Wii Console
The disc is unreadable but dosent say clean disc or anything
"Unable to read the disc" or "Disc could not be read" MessagesIf you are getting one of the above error messages:
Jan 23, 2011 | Video Game Consoles & Games
My DEH-1950 IS SHOWING ERROR 17 WHATS THE CAUSE? WHEN I PLAY A CD SOMETIMES IT PLAYS AND SOMRTIMES IT SHOWS THIS ERROR 17 WHAT COULD REALY BE THE CAUSE OF THIS.
Typical Error Messages from this head unit:
  • ERROR: 11,12,17,30 / Cause: Dirty Disc /Action: Clean Disc
  • ERROR: 11,12,17,30 / Cause: Scatched Disc / Action: Repace Disc
  • ERROR: 10,11,12,15,17,30 / Cause: Electical or mechanical / Action: Turn the ignition ON and OFF, or switch to a different source, then back to the CD player
Try a CD Head cleaner, that should resolve this error.
Nov 11, 2010 | Pioneer DEH-P2900MP CD Receiver...
Wont read game discs
    this is From wii web site:
Jun 12, 2010 | Nintendo Wii Console
When i put an Xbox 360 game in it tries to play it as a DVD movie. please help!!!
When you try to play a DVD movie or an Xbox 360 game disc on your Xbox 360 console, you may receive an error message. This article presents step-by-step guidance to help you determine whether your disc is playable.
Feb 18, 2010 | Microsoft Xbox 360 Console
Incorrect disc message
Sounds as if the carriage has been trashed somehow. Incorrect loading of a disc of any sort can cause this sort of message...accordianman
Mar 16, 2008 | Orion TVDVD092 9 in. TV/DVD Combo
Sony DVP-FX810 Portable DVD Player Logo
27 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
