Question about Garden
I need to replace the fuel line in a Craftsman DYT4000. Can you help me on thar?
Have a bad Craftsman fuel line. It is cracked
    Problem Solver:
  • 29 Answers
If you go to http://www.searspartsdirect.com/partsdirect/brands-products/Craftsman-Parts/Riding-mower-tractor-Parts and us the 917. model number you will be able to get exploded views of what you want..
Posted on Apr 26, 2014
3 Suggested Answers
  • 454 Answers
SOURCE: engine dies when i engage the blades on my
There is a safety switch that is connected to the seat, so that if you get out of the seat with the blades running, it will shut the mower off. That switch may be bad, or disconnected. Look for a pair of wires running up under the bottom of the seat. As a short-term fix or a test, you could connect those two wires together.
Posted on Mar 08, 2010
  • 6 Answers
SOURCE: hydro trans slips on dyt4000 craftsman
I'm having the same problem on a 200 and have narrowed it down to belt slippage. Problem is I replaced both pulley's and belt with Sears parts and made it worse. You can pull back on the brake/clutch pedal and it doesn't slip but there is no adjustment I can find. ANYONE got a CLUE
Posted on Apr 27, 2010
My craftsman dyt4000 will not start,battery is good turn one time and the starter smokes
if its a kohler motor replace the cam shaft
Briggs motor check valve train and or adjustments
to much oil in motor?
Bad starter
bad starter gear
bad gear on flywheel
Oct 11, 2014 | Garden
My craftsman starts and runs great,but when I start cutting it dies. it's new ran 1 gallon of gas through it.
Does it help if you keep the choke closed about half the way ? If it does check for a bad fuel line. I have had new ones with cracked fuel lines do this.
Oct 27, 2013 | Craftsman Garden
My Craftsman 17cc gas weed trimmer wouldn't start.
Hi There, Check the primer bulb for tare or pin holes. Replace it. Check and clean carb jet it maybe plugged with debree. Also check for spark which you didn't say. Replace with correct plug.
Note; Do not use strong cleaners on rubber seals (O rings and gaskets) They dry up and crack.
If needed use a dabble of grease on seals
Jun 13, 2011 | Craftsman Garden
I need a belt diagram for the mower deck on a Craftsman DGT 4000 mower w/ 48" deck... Can you help??
If you go to sears.com and click on parts. You will need to enter your model number-not dyt4000-but the model number on the machine's ID plate, probably with the serial number.
It will respond with your mower parts diagram!
May 07, 2011 | Craftsman Garden
Primer bubble is cracked.minimal fuel is getting to carburator. when it starts it will run a few seconds then cut off.Won't run except in full choke. Please Help
The primer bulb needs to be replaced. It is introducing air to the system and not allow fuel to flow. Replace it and check the fuel lines while you are at it.
HTH
Good Day
Oct 29, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman trimmer won't prime
A new carburetor would be simplest solution. You could try disassembling the carb, cleaning and replacing diaphrams, but just replacing the carb would be my choice. What is the model # on the trimmer and I can tell you the part # of the carb you need.
May 24, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman edger won't start
Does it have a primer bulb? If so, make sure the bulb is not cracked. Also, make sure the fuel lines are not cracked and the fuel supply line reaches the bottom of the tank. Fuel lines, as silly as it sounds, degrade when exposed to gas for long periods of time. If they are cracked it will draw more air than fuel and not allow the engine to run. You can buy replacement fuel line/primer bulb kits for under $10 at practically any hardware store.
May 24, 2009 | Craftsman Gas Mini - Tiller/Edger
Craftmen dyt4000
the manufacturers fluid recomendation should be written on the fluid cap or in your owners manual. if not most reecomend a 10W-30 synthetic blend
Oct 24, 2008 | Craftsman Garden
Garden Logo
83 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
