Question about Milwaukee tools Milwaukee Electric Tool 48-59-0180 CHARGER 2.4V 120V
Milwakee 48-59-0180 Battery Charger only charges 1 volt. Any ideas?
Only Charges 1 Volt
Need charging station for Shark Cyclonic 12 volt cordless power-vac
Buy a replacement charger from the Shark Cyclonic dealer. It is important that the specs match the battery, one or two volts higher can shorten the battery life by quite a large amount.
Aug 03, 2015 | Shark Vacuums
Will not charge the charging light is flashing
I'm not familure with your device but this is battery charging101. For a battery to charge the input voltage must be higher than the operating voltage of the battery. An example of this is your car. You have a 12 volt battery in your car and the alternator applies 13.4 volts or so to charge it. It is the same with any battery charger be it phone, laptop, chordless drill or small AA,AAA,C,D battery charger, that being said is the Dyson charger a seprat device? If so it can easily be tested at Batteries Plus, Any big box auto parts store, any high school electronics class. Check your owners manual it should give you the operating voltage, check that against what you discover about your charger. The charger only needs higher voltage output than the battery it doesn't have to bee a lot more. If you have further ? Email me at bret610@icloud.com good luck. Ps, you can by a reasonably accurate and easy use volt meter at W-mart for under $20. I am attacking video from u tube as to usage it's not difficult and well worth the money.
Sep 28, 2014 | Dyson Animal Bagless Cordless Hand Vacuum,...
I purchased a brand new P113 Ryobi charger about 2 years ago. It has never worked. If I put a P104 battery in for a charge, it looks like it works correctly. I push the battery tester on the battery...
If you have your receipt, check with Ryobi to see if it is still under warranty. It comes with either a 2 or 3 year warranty, depending on when it was purchased. If it is still covered, get it replaced/repaired. If it is not, buy the P117 charger. $30 at Home Depot. It has a 90 day satisfaction guarantee. If it charges your batteries properly, you're good. If not, bring it back if you don't like/want it. My P113 won't get out of test mode now, or charge Lithium batteries anymore. So I bought the P117 yesterday. Works great, and it's a lot cheaper than new batteries! And it has a 3 year warranty.
Aug 28, 2012 | Ryobi P113 18 Volt One Charger 140501001
Dirt devil doesn[t hold charge
Try running the battery all the way down by letting the vacume run in a corner or another room and even when it stops leave it on for a hour to drain the battery. Then shut the switch off and try charging the battery. Make sure the charger is putting out enough volts by looking at the rated output of the charger and while it is plugged in check it with a volt meter. If it does not hold a charge and the charger is putting out the right voltage you need to purchase a new battery for the vacume
Mar 18, 2011 | Dirt Devil Easy Lite Quick Vacuum
Will not hold a charge
if it will not hold a charge - then I would say that the battery is weak,old and bad and needs to be replaced. there is also a chance that the charger ityself is not putting out enough voltage to totally charge the battery. use a volt meter to check the charger and see if it is putting out the correct voltage,, if it is at the right voltage - then replace the battery.
c...
Mar 13, 2011 | Dirt Devil Vacuums
Light says its charging but it wont turn on
Well first of all you may check that the charger (adapter) is working or not, you may use a volt meter to check it out or use another charger to make sure....... further you may follow the step below -
1. Remove the battery pack from Vacuum.
2. Hold down the power button for five seconds.
3. Reinstall the battery to reset the system.
4. Plug the Charger directly into vacuum.
5. Charge the battery untill the power light is solid green again and keep the vacuum on the charger for an additional 72 hours (3 days). Important: Do NOT interrupt this charging cycle.
If further you have the same problem it means it's time to change the old battery with new one.
Good Luck!!
Thanks for using FixYa!!
Sep 18, 2010 | Dirt Devil KONE Hand Vacuum MO213BLU...
Light goes on my kone but it won't work
Good Luck!!
May 19, 2010 | Dirt Devil KONE Hand Vacuum MO213BLU...
My DC16 will start and then stop. I have to take
My DC16 also had charging problems. I called Dyson and they sent a new charger. The old charger only produced 23.6 volts DC, not the rated 28 volts DC. The new charger has a thicker round wire and produces 28.1 volts DC. Put a volt meter on your charger terminals and see if it is producing enough voltage to fully charge the battery, 28 volt DC. If not you need a new charger.
Jan 31, 2010 | Dyson DC16 Root 6 Bagless Handheld...
Want to buy a charger for Shark Cordless Sweeper
If you have the old charger, look at the pin and read the output. Many electronics clearance stores sell a generic charger which will match the output in volts and amps as long as you find the identical pin configuration. Volts may exceed the original battery rating by 20%, amps can as well. IE I have a 9.6 volt charger on my 7.2 volt battery pack.
Sep 06, 2009 | Euro-Pro S3325 Handheld Steam Vacuum
Milwaukee tools Milwaukee Electric Tool 48-59-0180 CHARGER 2.4V 120V Logo
113 people viewed this question
Top Milwaukee tools Vacuums Experts
JoeVacs
Are you a Milwaukee tools Vacuum Expert? Answer questions, earn points and help others
