Question about Westinghouse TX-52F480S 52 in. LCD TV
Tv does nit turn on
The orange light stays on but tv does not start up
Vizio vp422 orange light stays on wont power up
I would double check the capacitors on the power supply board. Make sure you don't have any that are bulged at the tops. Secondly, when you try and turn it on, does the orange light flash at all??
Jan 20, 2013 | Vizio VP42-20A 42 in. Plasma TV
When I turn our tv off the vizio emplem stays orange
According to the manual. It says The Vizio lights white when powered on and orange when powered off.
Mar 03, 2010 | Vizio VW42LF 42 in. LCD HDTV
Orange light will not stay on when the tv is off.
replace the power cord, do not use tv till you replace the power cord ok, you will eventually short circuit the tv or even worse blow the internal components
Jun 22, 2009 | Vizio L32 32 in. LCD HDTV
Lamp/cover light flashes orange
could be need new lamp
very expensive!!
how old is the tv?
is this the first lamp?
usually get 10000 hours use out of one lamp
Jun 01, 2009 | Televison & Video
Top up tv dtr box froze then staying on orange light, wont work
i had same problem today, it had locked up during deal/no deal
unplugged it three times nothing happened, wouldn't switch on
unplugged again left it for 5 minutes
then plugged in and left alone for 15mins plus
lights flasing then evetually green light went
all ok
May 03, 2009 | Televison & Video
Orange light re-set
Hold down the mute button on your remote and the
enter button on tv at the same time for a few seconds,
you should get a screen prompt asking if you want to
reset the lamp timer.
Mar 28, 2009 | Zenith E44W46LCD 44" Rear Projection...
TV turns itself off.
if you now how to used soldering iron , resolder your tv
Oct 22, 2008 | Televison & Video
Westinghouse TX-52F480S 52 in. LCD TV Logo
32 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
