Question about LG 47LN5700 47" LED TV 1920x1080, 120 Hz, HDTV, 3D
47LN5700 lines across the screen
I can see all the lines across the screen. I tried using the wizard to fix it but they are still there.
Lg 47ln5700
T con board is responsible for the image you see on screen.
Sep 15, 2017 | LG Televison & Video
I have a LG 47ln5700 smart tv. The screen goes black but the sound still works. I replaced the LED strips and the tv worked for about 4 hours and then the same thing happened. Any suggestions?
Bad power supply board can burn out those led strips. Recommend replacing both board and strips at same time. Lg 47LN5700 UH TV Parts
You can order most of the parts here.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Jan 11, 2017 | LG Televison & Video
LG model 47LN5700-UH LED TV. There is a single thin vertical line on the screen. I have changed the LED/Power Supply board and LED strips. What might be causing the vertical line?
You have wasted your time and money. The LED power supply and LED strips are only the backlighting. The only thing that might fix is a situation where you have a blank screen with the sound working.
If you don't know what you're doing, DON'T OPEN THE TV UP TO FIX IT, THERE ARE HAZARDOUS VOLTAGES ON THE POWER SUPPLY BOARD, EVEN WEEKS AFTER THE TV IS UNPLUGGED!
If you don't know how to do it yourself, find some local Electronic repair shops, get quotes, try to find reviews on the shops.
Nov 26, 2016 | LG Televison & Video
I have a 55" lg flat screen tv. All a sudden i turned it on and the screen was black. You can see a little bit of it on the screen but. Very light. I tried messing with the setting didnt work.
Hi Rachel, The link below is a YouTube video showing how to fix a Samsung television NO picture GOOD sound, Also there's videos down the right side of the link that may help as well........CHEERS..
LG No Picture Screen Flash 47LN5200 47LN5400 47LA6200 47LN5700 47LN5750...
May 01, 2016 | LG Televison & Video
TV TURNS ON,LINES ACROSS SCREEN THEN TURNS OFF BY ITSELF
sounds like a vertical problem, usually you'll see one white line across the screen, but one I worked on would come on and the bottom half of the picture was gone and there were lines across the top of the screen.
If you know how to solder & can find the vertical output chip then you could try resoldering the pins. If this doesn't fix it then it needs new parts.
Mar 08, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
White line going across screen of i pod classic
U HAVE A SCREEN IPOD CONNECTION PROBLEM, U  HAVE TO GO TO AN APPLE STORE TO FIX IT
Nov 28, 2009 | Televison & Video
Blue lines appear across screen during video playback.
thank you for choosing Fixya.com.
it seems that some parts in your Cam are Dirty.
please try to use the head cleaner disk first.
let me know if any changes happen.
goodluck
please don't forget to rate our answers properly.
Mar 03, 2009 | Panasonic Palmcorder PV-GS12 Mini DV...
Thin black line
Try to replace the YSCAN board. If not fix it, then it's the PDP Panel failure.
Jan 07, 2009 | Samsung FPT5084 50 in. Plasma HDTV
Lines on screen
These guys fix them
604-524-4926
Nov 12, 2007 | Sharp Wizard OZ-730
LG 47LN5700 47" LED TV 1920x1080, 120 Hz, HDTV, 3D Logo
54 people viewed this question
