Question about Remington Factory Reconditioned 17-Inch 3.0 Amp AXCESS Electric Hedge Trimm
Same problem. New last fall, quit after 30 min.
Took it apart and found a broken wire leading to one of the brushes, and the other brush was cracked. Now trying to find replacement brushes.
  • 188 Answers
The brushes for the trimmer is no longer available, so unless you can find someone who has old stock of the part, your going to have to replace this one.
Posted on Jul 13, 2009
Wire joins at the bushes
if the copper leads have broken off inside your brushes , replace the brushes with new , some tool mfg connect there wires in such a way that leads disconnect from brush when it wears down enough , this they believe keeps you from scoring armature to point of failure
Jun 03, 2015 | Saws
Hoover F7458-900 SteamVac The brushes quit
My Hoover F7458-900 was doing the same thing, brushes not turning and since it is about 7 years old and out of warrenty I decided I had nothing to lose so I took it apart after reading all the other posts on this problem. The brushes are actually turned by a turbine motor (no belts involved) that runs off air produced by the vaccum motor of the unit. The air turns a metal spindle that then turns several nylon gears in the turbin the last of which turns the brushes. The nylon gear that engages with the metal spindle was worn down to the point that it was no longer engaging with it and thus not turning.
The only fix for this problem is to buy a new turbin motor which is not that expensive about $34 plus shipping since they don't sell just the nylon gear. Hope this helps
May 23, 2010 | Hoover F7205900 SteamVac V2 Wet/Dry Vacuum
While operating machine, brush does not rotate. Button is pushed in, all hair cleaned off brush. Is there a reset button? Where is it located?
Likely the wires are broken under the left hand cover not a difficult fix. Unplug the machine and remove the 4 torx screws and an access panel at the side of the ball. replace wires with new or re-connect with a splice. ensure wires are long enough to allow movement and you don't trap the wires when you replace the covers. about a 20 min job with the right tools
Sep 26, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Motorized brush bar not turning on Dyson Vacuum
Apparent common failure is that either the thin yellow and or blue motor drive wires that run from the LH side of the vacuum where the "control board" is located down into the hinge / ball area become stretched and then fray and eventually break. Happened to my Dyson twice. First repaired under warranty, second took about 20 minutes. You need a Torx screwdriver to remove the LH panel ( 4 screws) and also an access panel (2 screws) at the side of the ball which permits access to the blue / yellow wire connectors. I replaced with a new wire and connectors having fed the wires through the access hole making sure sure enough wire was available for the movement of the handle. Also ensure that when the covers are replaced they do not trap any wires underneath.
Apr 02, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Hoover U6434-900 Brush roll not spinning, has new belt.
I took the top of the vacuum apart and found the cable that drives the wheels was broken. I am going to order a new cable.
Mar 22, 2009 | Hoover U6434-900 Bagged Upright Vacuum
Beater bar belt needs replacedon a dyson DC14 animal
Remove the glide plate at the bottom of rhe machine. Remove brush and broken belt. Fit new belt and re install brush. Fit glide plate, job done.
Its in the instruction book
Mar 08, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Flame
the first thing I would do is pull it apart and give the bricks a good cleaning with a wire brush to get any soot off. If they are broken beyond the point of replaceing them in the unit you will need new bricks.
Jan 18, 2009 | Desa International GWP20T GLOWARM Wall...
My new sonicare toothbrush has gone all wobbly.... on the bottom the following numbers to help you identify the model, etc: 080416 HX6910 the vibrating pin onto which the brush attaches is no longer...
Your suggestion worked! I took a small common screwdriver, carefully pried on the bottom plate on each side, a little at a time, and the whole motor assembly with O-ring, came out in one piece. There it was, a small phillips screw, in this sort of universal joint assembly at the top. I tightened it up, careful, its pretty small, won't stand too much torque, but it's tight now, and I think you saved me $100 or so, mine was getting so sloppy I expected it to fall apart any day, now it feels as tight as new.
Thanks so much!
Steven Fisher
Nov 07, 2008 | Computers & Internet
Brushes not rotating on my Hoover Steam Vac Dual
The brushes are all connected to a single shaft. This square shaft is connected to 2 sets of gears and then another shaft which is turned by an impeller (suction from the vaccum pump is used to turn the impell and thus the brushes). There are 2 bearings that the impeller shaft turns on. It's likely these are rusted up and just need a bit of WD 40. Took me 30 min to take apart, lube, and put back together. Remember, its plastic. If things won't come apart, look for another screw. Mine was a brand new unit and the top bearing was rusted.
Sep 22, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
Remington Factory Reconditioned  17-Inch 3.0 Amp AXCESS Electric Hedge Trimm Logo
265 people viewed this question
Top Remington Garden Experts
roeb
Phil Walker
Phil Walker
Joseph Mueller
Joseph Mueller
Are you a Remington Garden Expert? Answer questions, earn points and help others
