Question about Cardiac Science Burdick 8500 ECG
EKG leads not working
No reading from the leads
How do you change schiller ekg from 6 lead to 12 lead?
6 lead / 12 lead EKG. It is unlikely that you can do that with your machine. 6 leads are rarely used and would require a totally different internal format. 12 lead Ekg is the standard of care. Chose 12 lead and dont worry about finding a 6 lead. RJ
Sep 26, 2017 | Schiller Medical
What can I do about fasciculation, waist down
Since you have posted this in the section for EKG/ECG machines, I am surmising that you are referring to lower limb lead placement to decrease artifact on EKG readings. If you were my patient, I would simply move the lower limb leads up to the lower part of your torso where they would be less likely to be affected by movement from the fasciculations. It may cause a decrease in the deflection on the reading, but at least it will allow for a clearer overall "picture".
I hope this answers your question.
If your question was indeed how to cure the fasciculations themself, I would suggest discussing that with your neurologist. He or she is the only one who will have a clear enough knowledge of your whole case to be able to advise you properly.
Oct 12, 2016 | Medical
With leads hook correctly machine contuines to flat line
Check your RL (green) lead or trunk cable.
Right leg is the ground so (if it's bad) you won't get a QRS complex.
Jan 30, 2014 | Ge Medical Systems Ge Marquette Mac 1200...
How do I calibrate a MAC 1200 EKG machine?
First thing is first.
Hook your ekg machine up to simulator. Run an ekg using the simulator as a patient's heart. If you get a clean 12 lead printout with the interpretation reading "normal sinus rhythm" then I doubt that you need a calibration. If you get something else, I will need to know what it is that you got. there is no true "calibration." If there are issues, they are addressed. Otherwise, you are good to go. Keep me posted,
Discount Cardiology- The ekg machine experts
Nov 15, 2011 | Ge Medical Systems Ge Marquette Mac 1200...
Welsh allen at-2 lead light is on however ekg machine will not give tracing
hi,
There is some problem with the patient cable. Any one of the lead is broken inside. AT2 senses the presence of all the lead first and then only it will acquire the ECG and store it in its memory,after that it will print the ECG.
If any one of the lead have some problem. it will not go to the next procedure. and will indicate the lead off light.
1. check are you connected the lead correctly.
2. clean the electrode properly.
then try one more time. if problem remains. you have to replace the patient cable.
ok
Feb 04, 2011 | Schiller Welch Allyn Cardiovit At 2...
Ekg machine states left leg fail, but none of the leads are reading anything. works sometimes, but does this occasionaly. Does anyone else have these complaints?
hi,
ur machines patient cable have some problem in its left leg lead ,it may be broken inside. no ecg will come if any of the lead have problem. machine sences all the leads is it proper or not , then only it will process th ecg and give printout. u have to replace the patient cable of ur machine. or try to replace the left leg lead if it is repairable one type patient cable.
ok
Jan 10, 2011 | Life Science Bionet Cardiotouch 3000 12...
Won't give print out on Automatic but will give on manual
Turn off the machine & then turn on after 10 seconds. than press ALT 1 1 0 STOP in a sequence. That will solve your problem for printing in AUTOMATIC Mode
Jun 10, 2009 | Schiller Welch Allyn Cardiovit At 2...
EKG Machine
3 lead machines are designed to monitor the cardiac rhythm cycle, in 3 of the 12 primary leads. An attempt to use this limited information as a true diagnostic tool would be incomplete and perhaps misleading.
A full 12-lead machine is diagnostic, and looks at the elecrical information from all sides ("walls", ie anterior, septal, inferior, lateral, posterior) of the heart and gives detailed information regarding ischemia and or infarction of the cardiac muscle, electrical conduction system function, electrical axis, chamber enlargement, drug effects, and more.
Hope this helps.
Apr 23, 2009 | Ge Medical Systems 3 Lead Ekg / Ecg Cable...
MALFUNCTIONING LEAD ON ECG MACHINE
U may have problem with thorax electrode.
Apr 09, 2009 | Invacare Medical
I ahve a schiller welch allen EKG machine, and now it only prints
If it stops printing completely in the middle of doing the print, it is because the battery is bad and needs to be replaced.
If it only prints some of the leads but it does print the full report it is because you have the leads mixed up (Wrong spot on the patient) or the leads are mislabeled or some of the clips or electrodes are bad.
I can fix these. Let me know if you need help.
Apr 05, 2009 | Schiller Welch Allyn Cardiovit At 2...
Cardiac Science Burdick 8500 ECG Logo
73 people viewed this question
Top Cardiac Science Medical Experts
Andrew Taylor
Andrew Taylor
Are you a Cardiac Science Medical Expert? Answer questions, earn points and help others
