Question about 474L TX 4-Button Replacement TX Remote
New computer and keys - now the Avital remote start won't work
I have an Avital (the remote number is 474L). We had a new computer put in the car (2001 Toyota Solara SLE)and have new keys. The remote begins to start the car, but it doesn't turn over. What's the problem? How to fix it?
4 Suggested Answers
SOURCE: hi i have a avital
hi have you checked the battery or more so replace the battery and try it seems to be the only solution i know same problem happened to me and yes it was the battery goodluck
Posted on Jan 30, 2011
logosc75
  • 625 Answers
SOURCE: I bought a used car
The Camry you purchased may not be equipped with a power trunk. Press and hold the trunk button for appoximately 4 seconds. The trunk should release if the wire is connected and, you have a power trunk.
The Camry (and other toyotas) require a double pulse on the unlock wire. If the double pulse is not programmed the aftermarket unit will mimic the factory keyless entry. One press of the unlock button opens the drivers door. Immediately press the unlock button again to unlock the other doors.
Posted on May 06, 2011
SOURCE: i am looking for the user manual for the avital
my car alarm not working but i don't know how to set up.please show me how.thaks a lot
Posted on Jul 19, 2011
Avital remote start troubleshoot
Reset your PCM codes. Reset security codes -
www.ehow.com/how_6615404_program-used-keyless-entry-remote.html
Mar 07, 2014 | Vehicle Parts & Accessories
Doorlock operation won't work on new Avital 4103. Why? 1990Buick LeSabre
The door locks on the car are reverse polarity so u have to put realys in between the system and the door lock
Oct 21, 2012 | 4103LX 4Button Remote Start System with...
I lost my remote start key flob ,Avital 4113 ,so I ordered a new one from Best Buy and it comes with some instructions ,but they are not clear to me about how to get the system to accept new remote start...
Open door, turn ignition on, then off. Press and release programming switch once, then press and hold. Now press and release button on remote. Release programming switch. Remove key, test remote. Afterwards, repeat for second remote.
May 21, 2011 | 4113LX 1Button Remote Start System with...
I bought a used car toyota camry 2005 and it has avital key less remote system installed. model is 474L. It has remote start working and drive door open/close However, i am not able to open the power...
May 05, 2011 | 474L TX 4-Button Replacement TX Remote
Hi i have a avital key fob 474l that stop working two days ago it will not unlock or lock the doors.
Jan 30, 2011 | 474L Avital 4Button Transmitter 434 MHz...
Part wherer you insert key ring broke off on my two remotes. how can i get a replacement shell case so i can hang the keys on the remote.. that chep plastic strip where you can loop a key ring thru broke!
The casing is not usually available separately, but if you contact one of the product stockists (such as Directed Electronics) they may be able to provide you with contact details for the manufacturer. But the fault is due to a poorly engineered design so it's only a question of when it next happens. This time you've been lucky not to lose the remotes, next time you might not be so lucky.
The only remaining options are to either buy new remotes (expensive and has the same fault waiting to happen, plus you have to get them programmed to the alarm) or to fabricate a repair by drilling holes into the outer casing and then using strong wire (a section cut from a wire coathanger?) anchored with epoxy resin to fabricate a new and far superior key loop.
Good luck.
Sep 10, 2010 | 474L TX 4-Button Replacement TX Remote
Car does not turn over after pressing the button
Turned out to be low water in the battery cells. Once I filled them and let the car charge the battery properly the noise went away.
Dec 17, 2009 | 474L TX 4-Button Replacement TX Remote
Remote failure
Check your metal connection that you slide your battery in between upon changing it. I had the same problem in which my car issued a warning "FOB". And what had happened was one of my connections fell off my circuit board. So if you have a steady hand and a solder gun, it may fix your problem.
Sep 10, 2009 | 474L TX 4-Button Replacement TX Remote
474L TX 4-Button Replacement TX Remote Logo
162 people viewed this question
Top Avital Vehicle Parts & Accessories Experts
D. E. Hev
baire
Billy Mac
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
