Question about Fostex Mr 8hd CD 8 Track Recorder with CDr
Blank screen on and nothing is working
Screen is blank, nothing is working, I have used this and recorded before just fine but today it is not working
H1 won't connect via USB
This page has a download for a driver........ https://www.zoom-na.com/products/field-video-recording/field-recording/zoom-h1-handy-recorder
Also try a different cable....... Good Luck!
Mar 25, 2017 | Zoom H4 Handy Recorder
Zoom h1 handy recorder
Download the H1 driver for windows & try different usb cable........
Mar 09, 2017 | Music
I was using my recorder and it locked up. Nothing worked, I couldn't get any of the track arming buttons, transport buttons, the shutdown button, or the mute/solo buttons to work. the only thing that...
It sounds like the hard drive has failed... cheap test, get another and reformat the new one. They are so inexpensive now. To avoid losing data, they lock things up if anything goes wrong. The unit probably can't get the ready signal from the drive and freezes...
Apr 21, 2011 | Tascam 2488mkii 24 Track Recording...
Led screen is blank
Check the battery condition. Not all parts of the electronics fail to work as batteries fail... it can appear that the batteries are OK but high drain things like LED screens will not work even though other parts are working.
Feb 16, 2011 | Ovation iDea Celebrity Guitar with Builtin...
Sound won't come out when we try to play after recording. the thing worked fine for a while and now nothing. then it'll record fine but when we try to play what was recorded we get nothing. keep in mind...
Make sure the memory of the unit is not clear full. Strange things happen when things are full. It MAY look like it is recording, but it really isn't. Other thing is to make sure you have selected a song to play. Review the thing about structure of the files and folders in the manual. It looks like one can get lost in the menus on this unit.
Feb 13, 2011 | Korg Sound on Sound Unlimited Track...
Br8...the enter button has become harder and harder to make activate...now nothing. Everything in the unit works fine...except the enter button...which means that I cant record anything at all.
The button is obviously bad... The next thing is to determine what type button is used, It may be a small module or it may be a conductive rubber one. The latter, you take apart and clean with 99% isoprophyl alcohol and QTips. The module type you unsolder and replace the little module.
May 28, 2010 | Boss Micro BR Digital Recorder
I HAVE THE BOSS BR-900CD AND EVERYTHING SEEMS TO WORK FINE BUT NOTHING SHOWS UP ON THE SCREEN. IT LIGHTS UP BUT NO DATA SHOWS UP. THANKS
If all other controls are working, check IF they have a "Contrast" setting for the display. When those are at end of range, the display often is blank.
Mar 21, 2010 | Boss Music
Original circa 1982 Kurzweil Ensemble Grand upright, has been working just fine until today. At first the (grand piano) sound had just become very distorted or seemed to have messed up sustain or echoing....
Given its age, this unit needs a little TLC. Units of that vintage used some capacitors that may have dried out a bit and need to be replaced. There are also op-amp ICs internally that may be defective. I would suggest a visit to a service shop that works on keyboards as not all do.
Keep us posted.
Dan
Dec 08, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
I have the cubase le 4 and, everything installed fine but when i went to record nothing was happening the cursor moved across the screen but wasnt picking up any sound. i also got a message saying that the...
Try downloading Asio4all at http://www.asio4all.com/ and carefully following their instructions. There is good information under the FAQ/Troubleshooting section on their site. Id also recommend joining Recording Review for some great info. I think you can reach them through recordingrev001@aweber.com. Hope this helps.
Jul 09, 2009 | Lexicon Lambda 4x2x2 USB Audio Interface
BR1180CD does not regognize cd's.
Have You Tried Cleaning The Lens?
www.Myspace.com/CrossRoadsToNowhere2007
Dec 27, 2008 | Boss Micro BR Digital Recorder
Fostex Mr 8hd CD 8 Track Recorder with CDr Logo
32 people viewed this question
Top Fostex Music Experts
Ben Armstrong
rhodesworks
Are you a Fostex Music Expert? Answer questions, earn points and help others
