Question about T-Mobile Sidekick® 3 Cellular Phone
Cammera it has a green screen what do i do
Press the button with three lines and and the circle with the dots and p or r at the same time
Posted on Nov 02, 2007
Black screen web camera
Apr 20, 2014 | Lorex Home Security
My laptop shut down when on cammera after 3 minuts
In which case the webcam is faulty or your USB controller has failed. You could try and re-install the webcam drivers.
Apr 25, 2013 | Ema mb.n5402.001 - Emachines E525-2200...
Lost my plug in for the kodak easyshare c330 where can I get one to plug into camera and computer
If you want to download the pictures and movies from the cammera you can unload the memory card from the cammera and insert it in a card reader and then to the usb and without a cord you can do this easily, but you will get the cord in a cammera shop. available in your locality.
Sep 09, 2010 | Cameras
No image display on lcd screen
When i turn swicth onto Cammera, LCD screen and view finder is black ,some smears.Some time see a pictuer.
Any esle is Working good.
Mar 22, 2009 | Sony Handycam DCR-TRV33 Mini DV Digital...
Gigaware 25-157
was unable to install would not complete instation
Dec 16, 2008 | Radio Shack VGA PC Camera Webcam
Yep. another lens stuck.
it depends on what the problem acctually is. In my experience with cammeras such as these, a problem of this nature is not worth the trouble, but if you really like the cammera then take the covers off by removing the screws around the cammera body. Start by removing the back peace. you wont need to remove the door for the batteries or the two screws around the mount on the bottom of the cammera that hold the screw tripod mount in place. once you remove the backing you will expose at least one more screw on the side that holds the front cover on. you will want to very carefully remove the wires for the backing by pulling back the ribbon cable retainer clip and the ribon cable retainer clip must be pulled back carefully for the shutter switch as well when removing the front pannel of the cammera. Unplug the yellow wire for the micro switch in the front if applicable and then you will have exposed the lense. remove the screws holding the lense assembly in and then look around at the operation. THERE IS A CAPACITOR IN THE FRONT OF THE CAMMERA THAT WILL SHOCK YOU!!! DO NOT TOUCH THE BOARD. I've been shocked by the thing at least 3 times today so dont get all hasty. you will probably notice one of the gears are stuck or something you can buy a new lense assembly and install it but it is probably just as much as the cammera. I would sugges trying to repair it or if it is too damaged throw it away. It depends on what you find. you can look up small gears on line but it also may just need to be set back in or cleaned. You may also want to replace the cammera battery while you are in there. When removing the back pannel start from the bottom of the cammera and slightly hinge up and pull the backing away genly as to not snap the retainers in the upper part of the cammera or yank out the ribbon cable. REMOVE THE BATTERY BEFORE YOU BEGING. WITH THE BATTER REMOVED THE CAPACITOR WILL STILL SHOCK YOU. be careful.
Aug 16, 2008 | Olympus Camedia C-4000 Zoom Digital Camera
Fuji finepix A120
are you using rechargable batterys or weak batterys. my fuji won't work unless I use a e^2 titanium batterys. they have lots of jam (3500's?). anyways when the picture or ccd goes to charge there isn't enough juice to fire and the cammera dies. or maybe there is junk on the connections and won't let enough volts through. rechargeables are bad becouse they don't have the volt output needed - 1.2v charged I beleive. the other batterys are expensive but they've been in my cammera for three months, or about 300 pictures.
hope that helps :)
Feb 01, 2008 | Fuji FinePix A120 Digital Camera
Tuch screen not working
the connection of the control button of the lcd panel is cut....check the flex wire of the lcd
Jul 19, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
T-Mobile Sidekick® 3 Cellular Phone Logo
18 people viewed this question
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
Computer Repairing
Computer Repairing
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
