Question about Encore 78-6972-0030-7 Replacement Computer Cable For Cabl Mp160/mp180
Need a 78-6972-0030-7 replacement
Discontinued need something else
I want to buy a replacement brake handle for Bugaboo Frog. Bugaboo discontinued this model and don't have parts anymore.
my suggestion , would be to find a lawn mower repair shop (that's not too busy out of season) and nicely ask the attendant to make you a new brake , believe it or not , lawn mowers use a lot of similar things that strollers do (wheels, cables,tubing ,Etc.), and chances are they can with a bit of time make you something to work from what they have lying about . as this model is as you said .discontinued and no new parts are available
Feb 09, 2016 | Bugaboo Frog Baby Gear
Need motor brushes for kenmore vacuum
Chances are the part has been discontinued. You might want to check for a replacement motor. Sometimes panasonic may have something compatible. Good luck
Aug 30, 2015 | Kenmore Vacuums
My 1984 magna vf 700 ,the indicator light( fuel,oil, temperature gauge) allnot working
I own a 1984 Honda Magna VF 700. The speedometer broke and the part is discontinued. Is there another part that I can replace it with? Looking for something in stock to use and not concerned about original parts - just something that will work.
Nov 22, 2010 | 1982 Honda VF 750 S
Have same problem with handle
Same problem here. Anyone able to find this handle or a suitable replacement?? Thx
Aug 20, 2009 | Black & Decker Cst2000 12 - Volt Cordless...
Dacor touchpad
HI, this is a Element relay circuit failure. this relay is a separate PCB board with attached relays.
this relay board will need to be replaced.
CLICK HERE TO ORDER
Jul 19, 2009 | Dacor ECD230 Epicure Electric Double Oven
Encore 78-6972-0030-7 Replacement Computer Cable For Cabl Mp160/mp180 Logo
Top Encore Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Encore Audio Player and Recorder Expert? Answer questions, earn points and help others
