Pull the fuse F15 in the under hood fuse panel. Turn the ignition off when the wipers are down, then pull the fuse. You may need a new stalk that the switch mounts on, or a ground wire has worn through the insulation that goes to the wiper motor. The constant back and forth motion of the wipers can sometimes wear insulation of wiring, so check your wiring near the wiper motor. https://youtu.be/pgehXDvBO8c
Hi there: It is located in the engine bay, lift your hood. Look behind the passenger-side headlight. Under the fuseblock. The silver finned block with the two huge wire bundles hooked to it is the ECM. Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
