Question about Delfield CAB2-1013QT Quick Temp Mobile Enclosed Two Stack Heated Dish Dispenser / Warmer for 9 1/8" to 10 1/8" Dishes - 120V
Watch strap I got a chronolech watch with the strap has a metal piece which I do not know how to put it together.
Timex T78587. The pin holding the metal strap to the time piece has snapped off. Is that repairable?
Take the watch to a jeweller or you can fix it yourself. That pin in the watch is removable. Use the tip of a jewellers screwdriver to push the ridge inwards. You should be able to fold the end of the strap back around it. If not, they will sell you a new strap and fit it.
Dec 18, 2016 | Timex Watches
How di i change the batteries in my Casio Pathfinder 2782
  • Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
  • 2
    Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
  • 3
    Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
  • 4
    Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
  • 5
    Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
  • 6
    Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
  • 7
    Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
  • 8
    Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
  • 9
    Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
  • Best regards. Jewel
    Sep 20, 2010 | Casio PRG-40T-7 Pathfinder
    I HAVE A CAR SEAT THAT I TOOK APART IN ORDER TO WASH THE CUSHIONS BUT NOW I DONT KNOW HOW TO PUT THE STRAPS BACK TOGETHER
    There is normally a splitter in the back, a metal piece with two hooks that is attachted to the adjustment strap. the sholder straps latch onto this. You can locate the appropriate manual here: http://www.coscojuvenile.com/usa/eng/Instructions The pages in the back normally discuss reassembly after cleaning.
    Mar 19, 2010 | Cosco Alpha Omega Elite 5-Point 22-155
    I took off the cover to wash and now I'm trying to figure out how to get straps put back on
    This will help if you lay out the chest pieces and all the pieces you removed on the table first. If it helps, snap them together. Then, lay out the pieces with metal prongs that lock into the buckle that goes between your child's legs.
    1st pull through the belt adjusting piece through the bottom cover ****.
    2nd pull the square release buckle through the second ****, on top of the piece that tightens and releases. This is the piece that you push with your thumb to release the seatbelt.
    3rd pull both side seatbelts through the respective side right and left and make sure they are flat.
    4th slide on the two pieces with metal prongs on one left and one right seatbelt. Before you do this, ensure that you have put the correct piece on the correct side and that they will latch properly into the buckle. Snap them into the buckle to ensure you have it right.
    5th attach the two respective chest clips on one right and one left seatbelt. Snap them together to ensure you have it right.
    6th pull the top shoulder seatbelt straps through one of the top cover slits. If you have a newborn, then it will be the bottom **** at the top. If your child has grown, then it will be the top two slits. Ensure both seatbelts are pulled either through the same **** on either side.
    7th after you have pulled the shoulder straps through the top slits on the cover, pull them through the slits in the plastic carseat frame. Pull them through until you see them at the rear.
    8th attach on their respective sides the shoulder strap at the back of the plastic carseat. There is a big brass metal piece with "hooks" at the top. The shoulder strap has a seatbelt "loop" on one end that can be hooked on. Do this on each respective side and make sure it is secure.
    Oct 26, 2009 | Graco Snugride
    The strap is broken on casio watch
    I had exactly the same problem with exactly the same model watch, and it happened to me twice. The AQ-160 is the important part of the model number as far as replacement parts are concerned. The first time, I took it to the shop where I bought the watch, and they replaced the band, but it cost me $50. The second time, I looked up the Web for the master agent for Casio in Australia, and they said I could buy the end piece, not the whole band, for $6. I found I could replace it quite easily myself by using a drawing pin to remove the spring pin that holds it together. A bit fiddly to reassemble but not too bad. In fact, I didn't wait for the new part to arrive, just used the unbroken end of the old band. So now I have a repaired band plus the old band and a new end piece, in case it ever happens again.
    I really like this watch, but it is a pity the bands are so weak.
    Aug 14, 2009 | Casio Watches
    WV-57H Watch - how do you replace the strap? I have a new strap for this model and can't work out how to take the old one off and fit the replacement. Thanks
    If you look at the watch from the side, you'll see that there's a two-part metal piece on the underside of the watch on each side.  The metal piece is a spring-loaded pin going through the strap which is holding on a larger metal piece.  You need to get another small pin (or an eyeglass screwdriver might work) so you can poke in the end of that spring loaded metal piece, which will allow you to slip off the larger metal bracer.  Then you can poke the spring-loaded pin entirely out of the strap and it will be freed entirely.
    To help you visualize what you are doing, the spring-loaded pin operates similarly to a toilet-paper roll - you need to compress the pin so you can slip off the larger metal bit, then take out the pin, which will free the strap.
    Oct 30, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
    Nania 3 in 1 carseat
    i have lost instructions for nania 3in1 ihave got all the straps but cant put i t together can i download instructions please help
    Aug 10, 2008 | Nania Nuevo 3-in1
    Cosco 5-point omega carseat
    ok I had such a hard time with this, i looked on the internet for hours and found NOTHING!! haha so i went to babies r us and checked out a similar one so here it is.
    first the strap goes on the bottom, pull them even and the add the buckle, plastic buckle thing, and the other thing soft thing. then put the strap through the back of the seat (you should have two ends) not the must go OVER the adjusts! now take the metal piece that adjust the length and pull it long enough for it to reach the two straps and hook them up!! haha if this isnt good enough go to a store that carries the alpha omega elite car seats and check it out! GOOD LUCK!!
    May 10, 2007 | Cosco Alpha Omega Elite 5-Point 22-155
    Delfield CAB2-1013QT Quick Temp Mobile Enclosed Two Stack Heated Dish Dispenser / Warmer for 9 1/8" to 10 1/8" Dishes - 120V Logo
    414 people viewed this question
    Top Delfield Retail Supplies Experts
    Electroboy
    Electroboy
    Are you a Delfield Retail Supply Expert? Answer questions, earn points and help others
