Question about Naxa NID-7006A Core 7" Tablet Computer, A13 Cortex A8-1.2GHz, 512MB RAM, 4GB Built-in Flash Memory, Android OS 4.1
Factory reset when in the reset menu it has a sign above it
How do. Do a factory reset on a Lenovo tablet TB-X103F so it is like new without having to sign in when setting up so I can sell it so someone else can use it. What are the steps
Hi step 1 turn of tablet step 2 press & hold : volume up + volume down + power buttons step 3 in recovery menu use the volume down button to move the highlight & the volume up to select step 4 choose one by one"wipe data/factory reset "Yes delete all user data" and finally "Reboot system Now". Cheers
May 14, 2017 | Lenovo Tablets & eReaders
How do i factory reset a Nexa Corona 7 tablet
To help you understand to perform factory reset for Nexa Corona 7 tablet, please follow the instructions given below:
- Make sure before performing factory reset, you take all the data backup from the tablet.
- Switch OFF the tablet completely.
- When it is completely switched OFF, press and hold 'POWER' and 'VOL+' together until you see a picture of the android robot lying on his back.
- Tap the 'Power' button once.
- You will see a menu, use 'VOL-' to move down in the 'Menu'.
- When you get to the 6th item (factory reset), press 'VOL+'.
- Do the same on the next screen to navigate to 'Yes' and wait for the time to finish the factory reset.
GuruAid.com
Jun 08, 2016 | Tablets & eReaders
How to restore a amazon kindle ereader to factory settings
Try: Menu/Settings/Reset to factory defaults.
or Menu/Settings/Menu/Reset to factory defaults
Oct 02, 2015 | Amazon Tablets & eReaders
When I turn on my tablet it just keeps displaying "Restarting", what can I do?
Did you try factory reset?
You can make this from Android Recovery Menu (this will erase all your personal data!!!)
Pres and hold VolUp and PowerOn keys until you see android logo.(for a samsung tab)
Use VolUp and VolDn keys to navigate in the menu and PowerOn for OK.
Choose wipe data / factory reset, yes erase all data and finally - reset.
Factory Data reset / Hard reset
Regards.
May 28, 2015 | Tablets & eReaders
Where is the reset button on the kindle fire?
According to eHow.com: " E-Reader Soft Reset
  • 1 Open your Kindle's Menu while on the Home screen. Do so by pressing the Menu button, or the onscreen Menu icon for Kindle Paperwhite owners. Select the "Settings" option.
  • 2 Choose "Menu" again from within the Settings menu. This displays a different menu than before.
  • Sponsored Links
  • 3 Choose the "Restart" option. Wait while your Kindle powers off and on again.
E-Reader Hard Reset
  • 1 Charge your Kindle e-reader before performing a hard reset. Charging helps ensure your problem isn't related to the device having a low battery.
  • 2 Hold down the Power button for 20 seconds. The screen will change after a few seconds, but continue holding the power button for the full 20 seconds before releasing.
  • 3 Wait while your Kindle restarts.
E-Reader Factory Reset
  • 1 Press your Kindle's Menu button. Select "Settings" from the menu.
  • 2 Open the menu once more from within the Settings window. Select "Reset to Factory Defaults," or "Reset Device" if you're using a Paperwhite.
  • 3 Select "Yes" in the confirmation window after reading the warning. Wait while your Kindle restarts and restores.
Fire Soft Reset
  • 1 Hold the Power button down for three to five seconds. A Shutdown window appears.
  • 2 Tap the "Power Off" button in the Shutdown window. Wait for the Fire to shut down completely.
  • 3 Press the Power button to turn the device on again.
Fire Hard Reset
  • 1 Plug your Kindle Fire in and give it time to charge before performing a hard reset. This helps ensure your issues aren't related to having a low battery.
  • 2 Hold down the Power button for 20 seconds. The Kindle Fire will shut down.
  • 3 Press the Power button to turn the Kindle Fire back on.
Fire Factory Reset
  • 1 Swipe your finger down from the top of your Kindle Fire's screen, presenting the Quick Settings menu.
  • 2 Tap the "Settings" option and select "Device."
  • 3 Select "Reset to Factory Defaults," then tap the "Reset" button. Wait while your Kindle Fire restarts and restores.
Read more : http://www.ehow.com/how_6122863_reset-kindle.html
May 10, 2015 | Tablets & eReaders
How do I reset my 7 inch polaroid tabet to factory defaults?
Patty, I'm first assuming you can at least boot the tablet to the menu screen. Scroll over to the settings menu. Scroll down the settings menu to backup and reset. You then have two options given: Back up my data or Factory data reset!
Oct 18, 2014 | Polaroid 7" Internet Tablet Android 4.0...
Nook
You have to reset your tablet to Factory Settings.
Reset to factory settings (means you will loose your apps) to do do this most tablets gets reset by presing both (Up-Down) volume keys before pressing the power on button.
A text menu will appear asking you the action, you have to choose Factory Settings.
Your Tablet must be power off before to perform the above procedure.
Hope it helps...
May 01, 2014 | Coby Kyros 716829701508 Tablet PC
Reset
Factory Reset: go to Settings from the home screen. Click on "Privacy" and then click on "Factory Data Reset." Go through the data reset process. This will remove all personal data from the device.
Or
Shutdown the tab, enter the recovery console by holding both the return button and the power button until you see the android icon with a triangle. Press return button again and recovery menu will appear. Navigate through the recovery menu using vol up/vol dn or home and menu buttons on the tablet. Select "wipe data/factory reset." and then "reboot system now"
Apr 22, 2014 | Coby Kyros 716829701508 Tablet PC
How to factory reset
For factory reset:
  1. Take SD card out, power down.
  2. Replace SD card.
  3. Press and hold power AND volume buttons.
  4. When the device powers up, it should have the troubleshooting menu (that's what I call it at any rate). Select Factory Reset (some also says Wipe/Delete Data).
There are some people who states to re-flash the ROM. You would do this by downloading the .zip file from
http://www.freaktab.com/showthread.php?7012-Amlogic-Next7P12-8G-Modified-Recovery-Stock-Rom-amp-Flashable-Root
and unzipping the files to the SD card on your computer before inserting it into the device. Personally, leave the second bit as last resort, though (if used) is done similar to the steps I gave above.
Mar 05, 2014 | Nextbook Premium Series Next7P12
After factory reset of my kobo glo, I couldn't get back my books that I ?
First make sure your books are really (still) in your account. Log into Kobobooks.com and check your library. Here's a direct link to the library page: Sign in to Kobo with
If you don't see your books there, you didn't buy them under that user account, or they're been removed from your account. Call Kobo support in either case.
If the books are there, make sure your Kobo eReader is also logged in using the same account. To do that,
1 - Open the menu
2 - Tap Settings
3 - Tap Account
Under 'Signed in as', you should see your user account. If not, tap in Sign in and log in. After that you can sync your library with your Kobobooks.com account from the menu again.
Dec 18, 2013 | Kobo Glo eReader Silver - N613-KBO-S
Naxa NID-7006A Core 7" Tablet Computer, A13 Cortex A8-1.2GHz, 512MB RAM, 4GB Built-in Flash Memory, Android OS 4.1 Logo
41 people viewed this question
Top Naxa Tablets & eReaders Experts
Are you a Naxa Tablet and eReader Expert? Answer questions, earn points and help others
