Question about Alfa Network Alfa R36 USB-enabled Wi-Fi Router AWUS036H kit
Alfa r36 problem
Router boots normal when no lan attached. When I connect the lan connector the power led start blinking and the other leds (lan, wlan, wan) switch off
How do I connect my iPad to r36 and awuso36nhv with no laptop?
Not sure you can.
iPad is on iOS and I am not sure they have the proper drivers for the chipset
Contact Alfa Networks
Feb 14, 2015 | Alfa Network Alfa R36 USB-enabled Wi-Fi...
WHAT LIGHTS ON LINKSYS ARE SUPPOSED TO BE BLINKING
Note that incoming traffic will cause the WAN (or Internet) light to blink even if it is 'probe' traffic trying to break in to your network. Such traffic is to be expected and is the reason you have firewall functionality in your gateway router.
On the inside, there is a bit of traffic on any LAN when the computers are turned on. Messages generated by the router itself are used to find computers and printers for a lot of different legitimate reasons.
Feb 25, 2013 | Linksys Wireless-G WRT54G Router
I have a router Netgear fwp114pv2 .. power led and test led blinks and the router stuck at this blinking
Try RESETTING the router.
To RESET the Netgear, power up the Netgear then press andhold the RESET button at the back of the router until all the LEDs flash. Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password You can now change the admin password and configure thewireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jun 09, 2011 | NetGear FWG114P Router (FWG114PAU)
Need to connect Linsys to motorola modem for wi fi usage
  1. simply unplug the router and the modem from their power source
  2. plug the power cable into the modem
  3. wait for the lights to stop coming on, until you see solid power and internet connectivity LED and an intermittently blinking activity light.
  4. now plug the power to the router and allow it to boot all the way up as well.
  5. no your internet should be workin. (the ethernet cable should go from the LAN port on the modem to the Internet port on the rear of the router, and any desktops should be connected beginning with the LAN 1 port and advancing as required)
Jan 08, 2011 | Linksys Wireless-G WRT54G Router
Switch with 8 leds blinking (and not working)
You probably have to buy another switch. However, before you try that - the eighth most right cable - switch that out to see if it was a cable problem. That's an easy thing to try before you buy another switch.
Mar 17, 2009 | D-Link DGS-1008D 8-Port Gigabit Ethernet...
LAN led light alway on and flashing
Reset the router:
While the router is powered on press and hold the reset button for 5-10 sec. Release the button and wait until the router boots up (1 min).
If this does not work then you can try this
Try setting it into recovery mode and loading firmware:
Unplug power cable from the router and press the reset button. While holding the reset button plug the power cable in. Continue holding the reset button untill you will see LEDs on the router flashing rapidly.
You should be able to log into the router - you will see a prompt to load firmware. The firmware is available on our WEB site: http://www.dlink.com.au/tech/
Note - suggest you d/l the firmware BEFORE you reset router
Jul 05, 2008 | D-Link DI-704P Router
No power led, wlan led blinking
well, what you could try is unplugging the power source from the cable modem, and the router. wait about 1 minute. then plug everything back in and wait.
i remember having this problem as well, but i think the problem with me was that my wireless computer was too far away from the wireless router, not saying that your too far or not, but that what i had, so i just pitched the wireless adapter, and created an ethernet connection. just sharing my experience.
Feb 26, 2008 | D-Link DI 514 Wireless Router (DI-514)
Problem after firmware update Edimax BR-6114Wg
Hi Fklco,
Why are you connecting the WAN,, (the internet modem cable), to the standard ports? It should have a WAN port, for the cable from the modem, and a LAN for the cables to the computer?
On the other hand, if it is working, I would leave well enough alone, :D
Jan 06, 2008 | Edimax BR-6114Wg Router (BR6114WG)
Can't access settings page
the web page of your router cannot be changed by the isp, but what may have changed is your network cards ip address, as thats the only wat the router cannot be reached if you are on a different address route, so check that your card is 192.168.0.X, the last being different to the router. the only other way this may have happened is if you have used an installation disc and it has changed all address so that they are different to what the routers manufactured address is and therefore cannot be altered but is allowing a static ip address or mac addresses for internet connection. The outer may have simply froze out, and you may have to reset the router by way of a pin hole button at the rear of the unit or underneath or firstly try a restart by unplugging it.
May 11, 2007 | NetGear MR814 Wireless Router
Wireless LED blinking, normal?
Same problem here - wireless light starts blinking and I get a network interruption. At that point, I have to walk across the house and downstairs to cycle the power on the router to get it working again. What a pain - and the manual doesn't even mention a blinking status for that light. I'm thinking about hooking the router up to a automated power switch (X12) so I can remotely cycle the power.
Dec 17, 2006 | NetGear RangeMax WPN824 Router
Alfa Network Alfa R36 USB-enabled Wi-Fi Router AWUS036H kit Logo
52 people viewed this question
Top Alfa Network Computers & Internet Experts
David Payne
David Payne
Are you an Alfa Network Computer and Internet Expert? Answer questions, earn points and help others
