Televison & Video Logo
Posted on Jun 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 2000 55in big screen. i unplugged the tv when i plugged it back in the green light just keeps blinking won't reset.
Sonny Berry
Level 3:
  • Master 8,617 Answers
  • Posted on Jun 15, 2009
Sonny Berry
Master
Level 3:
Answers
8617
Questions
Helped
1721633
Points
23750
Its ounds as if your talking about a mitsubishi that has the DM capacitor problem. Let me know the model number and I can assist you.
My mitsubishi tv W55613 won't turn on. green light keeps blinking even after resetting
Hit the front of the tv near the blinking light... give it a good rap or two. See if this helps. Helped mine. I had the same problem and the tech who came out to the house told me that it would work and it did! I could hardly believe it but it worked.
1 have a 6 year-old Mitsubishi model WS-48511 series 1080 rear projection TV that now won't turn on. A few days ago we shut the TV off, and now when i plug it in the blinking green power light...
This is called the blinking green light of death-----only one of two things can cause this problem.
First: remove front speaker grill (IT PULLS OFF) AND remove inspection plate behind it; look for the two bundles of wires coming down and to the right from the front keyboard of the set.
Unplug both plugs you find (different and marked so you cannot mix them up-----the idea is to take the front keyboard out of circuit-----set will still function with remote as receiver is behind front screen)
Try (after 70 seconds) to turn on with remote
If it comes on---defective reset button on front keyboard----use set only with remote or remove and remove actual reset switch---it is located behind and part of frame for screen----entire front screen would have to be removed to get at it.
Second: if disconnection of the front keyboard does not help, the DM unit is bad.
As you look from back of set it is large metal box at extreme left side.
The blinking light is the unit trying to "Boot" up-----these have a problem where caps and a few other parts in that unit fail-----kits on the net are available----Mitsubishi no longer sells or services these units but PTS Electronics does repair them.
Let me know if you have questions and try disconnection of the front keyboard FIRST.
REGARDS, SD TECH
The green light on front of tv keeps flashing and tv wont turn on
Howdy,
The green light blinking indicates your TV has a problem. The problem is that each Brand of TV has different codes and with out the Brand and Model number, I can not help you at this time.
Please, count blinking sequence. Model number will be on back of TV.
Recap : Provide Model Number, Brand and Count Blinks.
First though; unplug TV from power source for 3-5 minutes then plug TV & box back into a/c outlet.
Good Luck, BIG IRISH.
24helpful
3answers
Green light blinking
The green light on the front blinkes and does not stop even after hitting re-set button.
3helpful
2answers
Blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
1helpful
4answers
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
2helpful
Sharp LCD LC-46D64U
Try resetting the TV. Here's how to do it - Unplug the TV's power cable. Keep the Channel Down and Volume Up buttons on the TV pressed and plug the power cable back into the outlet. You will hear a click when you plug it back in if the reset is successful. Hopefully this should restore your video and audio.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
