Question about Sony VAIO VGN-CS118E/P NoteBook
Touch sensor A/V controls
Dosent not work
I replace the sku 65220 screen now it dosent work wut did i do wrong
That is nearly imposs to say, but the common issue would be a poor connection to the board.
Feb 06, 2012 | Cell Phones
I have had several technicians at my parents house they have a sanyo pdp42xr9da with remote rcj17oa the remote dosent talk to tv we have had the tv for two years it did work but now dosent please suggest...
Most of the fault in this kind of symptoms is the remote control itself.
To confirm it, aim directly the remote control to your cellphone camera and press any button key at the remote control. While pressing the button key, you will be able to see the flash of the infrared indicating that the remote control is working fine. If you can't see the flash of the infrared this is an indication that the remote control is already faulty.
Remote control
If you've confirmed that the remote control is working fine, then the fault came from the infrared receiver(sensor) of your tv. It needs to check by the qualified technician to isolate the problem.
Feel free to ask question of you need further assistance.
mjsazon
Oct 04, 2011 | Televison & Video
My touch screen dosent but everything else dose
If your touch screen is not working, theres just 2 major causes of such, either a hardware cause which might be either the phone falling on a hard object or in water which could damage the sensor board and either the screen is malfunctioning and needs to be calibrated.
If you can access the menu of the phone, i will advice you calibrate the screen first before you send it to a repair shop. There is no updates to download for such problem as updating the firmware of the phone would do nothing but change the settings of the phone.
To calibrate the screen, you will have to go to the phones menu, go to settings, then you select the calibrate screen, it will show you some stars to touch and once you touch them properly, then your screen will be able to work effectively.
But if you cannot access the menu because of the touch, then i will advice you send it off for repairs, and what to repair on the phone is the sensor board.
Hope this helps you.
Jun 18, 2011 | LG Cell Phones
My touch scrine dosent work. each time i touch,it pop up nothing.
Touch screen problem
But if you cannot access the menu because of the touch, then i will advice you send it off for repairs, and what to repair on the phone is the sensor board. (control pad).
May 22, 2011 | Acer beTouch E100 Cell Phone
My 2000 ford expedition what it does when i turn it on i have to wait at least 10 minutes to warm up. And while im waiting my rpm neddle goes up and down and the truck feels like it wants to turn off. ...
might have a bad temperature sensor or thermostat . and if the rpms are going crazy there is a tps sensor throttle position sensor and an idle air control valve also check the wires going to these devises i had a wire cut and replaced the tps and it still din`t fix it it was a bad wire do a little looking around see if wires are touching or rubbing on things they are strapped to . also do you have a check engine light on . and have you done a tune up lately
Mar 09, 2011 | 2000 Ford Expedition
My touch screen dosent work on my htc fuze.. the visual aspect is fine but it just dosent respond to any touch.. not even with the stylis. has anyone had this problem? if soo please help im still under...
Hey your touch pad would have gone for a toss. Between your touch pad dont have any relation with ur display so thats wy your display is working fine. As you are in contract, you can always go and claim for a free service or also free replacement of mobile. If you argue better you will get a free replacement rather than free service.
Aug 01, 2010 | HTC FUZE Smartphone
New control module and coil still no spark
crank sensor. im almost positive, on the driver side under neath your car on the bellhousing of the transmission is a sensor, first try unpluging and pluging the sensor,, most times it will start working, if it dosent youll need a new one. its a total do it yourself job. its only two bolts and a connection
Mar 13, 2009 | 1998 Jeep Cherokee
Cruise control dosent work on 1999 F150
Check to see if you have any relays. Also make sure vaccuum hose is still connected.
Feb 11, 2009 | 1992 Ford F150 SuperCab
Ds touch screen not working
wow try the ds screen calibretion if that dosent work you may need a new touch screen
Jan 12, 2009 | Nintendo DS Lite Console
Sony VAIO VGN-CS118E/P NoteBook Logo
18 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
