Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
Dyson animal won't push on carpet; turning off then on works for
This vac is 2 years old and has been working fine up to now. Took off belt and checked for debris in the area, but found none.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 83 Answers
First check to see if the gray plate that you removed to access the brushbar is back on the machine properly. Also, make sure that the long black strip on the plate is on properly and is not making it harder to push the machine.
Lastly, you are able to remove what is called a "ropeseal" from the bottom of the machine which will allow more air to flow underneath the machine. This won't affect the suction power of the machine.
To remove the ropeseal, take the gray soleplate off again and have a look at what would be the inside of the plate - you'll see a long, thin piece of rubber/foam that looks like a rope/string sitting in a groove all the way around the openings that the brushbar bristles stick through. Remove the seal and keep it in a safe place. Your machine will be easier to push now.
Posted on Jul 30, 2009
Animal ball great on tiles but carnt push it on a thick carpet turn it off and it's fine but turned on no chance ,, get cheep vac out that's fine ,, head by the way not blocked all free
Yes that's a nappy carpet verses long brushes, plus awesome suction. If you have a trigger to relieve suction a bit you will just have to nurse it. One direction of nap is always easier than the other. Eventually your Dyson will suck yourcarpet up, making it thinner, and the engine will tire and those long brushes will wear down and it will be just right
Feb 06, 2017 | Dyson Vacuums
Hard to push across carpet
Check the belt that drive the brush not broken or brush not clogged up.
Oct 01, 2016 | Dyson DC28 Animal Upright Vacuum New DC 28...
We love our Dyson DC25 Animal but we just got new carpet and it's like pushing furniture around the room. I know it doesn't have a height adjustment but is there any other option?
Hi there, it's Jack at Dyson.
I'm sorry to hear you're having difficulty using your DC25 Animal on this particular type of carpeting. This sounds unusual especially as it worked effectively on your older carpeting. As DC25 is engineered to adjust automatically to different floor types and pile heights, there is unlikely to be an issue with the vacuum itself.
It may be worth checking directly with the carpet manufacturer for their guidance on caring for this specific type of flooring. Manufacturers will sometimes recommend vacuuming certain types of long-pile or delicate carpeting with the motorised brush bar turned off.
If you'd like any further guidance from our experts, you can reach us by calling the Dyson Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
May 11, 2014 | Dyson DC25 Animal Bagless Upright Vacuum
My Dyson D17 Animal vac makes a buzzing noise when the belt turns. I took the belt off and turned the small metal gear that turns the belt. That is what is making the slight noise. My wife vacuumed the...
Try not to **** up any more water. Don't use until you can dry it out well. Hopefully you live in a warm climate so that will happen sooner than later.
Sep 23, 2013 | Vacuums
My Dyson - DC14 won't push on my new plush carpet, front end
Same issue: new plush carpet, 7 year old tried and true DC14, wouldn't push across regardless of beater brush on or off. Called Dyson this morning, they suggested removing the small gasket between the floor plate and the assembly holding the beater brush. It's about a 12' gasket just under the screws used to remove the floor plate. Pushing is still a bit stiff, but it is a definite improvement. Whew!
Jul 29, 2012 | Vacuums
Carpet
have a look at the brushes are they turning and if they are can you stop them turning if you tuch them with your hand??? if you can stop them turning the brush drive belt is slipping get a new belt and fit it,,
problem sorted!!!!
Jun 25, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
I have a Dyson Animal vacuum - about 3 years old - and the beater bar won't turn. I can't find my manual anywhere - any suggestions as to the cause?
There is a part under the knob that adjusts from bare floor to carpet that goes bad on these vacuums. I have an animal that is about 3 or 4 years old and I had it repaired last year( to the tune of $115.00), and it broke again in December, so I just bought a new one, tired of paying high repair cost!!
Jan 05, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
When pushing foreward the vacuum is hard to push and if pushed on to hard it will turn over on itself.
Check the brush. That could be the problem. Check the belt also. Your brush roller may need to be lubed or even replaced.
Sep 04, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson suddenly hard to push on carpet
I know this sounds silly, but it works. Turn it over and wipe all the black residue off the bottom of it (off the plastic on the bottom that rubs on the carpet as you push and pull it). I thought my husband was out of his mind when he told me that was the solution, but it really works.
Jun 02, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
432 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
