Question about Kelvinator Refrigerators
N501V WANT SIZE OF FRIDGE
My fridge compressor is not running. I removed the thermal cutout and relay to replace. The parts list shows a capacitor which my fridge doesn't have. Is this required for my model? WSE6070SB model no
Yes
the start /run capacitor is required to jolt start the compressor with an over voltage and then to keep it running
fridge capacitors are generally flat squarish and yellow in color about 1/2 the size of a match box
get in a fridge technician to properly diagnose the fault and save money
Jul 21, 2016 | Refrigerators
WHAT THE CUBIC FOOT SIZE FOR THE MEASUREMENTS OF 62"H x 23.5"W x 24"D?
The cubic ft capacity spec on a fridge is measured inside, and varies depending on its design, especially on whether it has an ice maker, although those measurements you give seem to be for a bar fridge or similar.
Your measurements come to 20.3 cu ft on the outside, but remember that is not relevant, you have to measure the dimensions to make sure it fits.
Feb 25, 2016 | Refrigerators
Cubic feet of my fridge and freezer model #ED5CHQXVQ00
The model number usually depicts what size fridge it is. ED 5 ?? That would suggest 5 cubic feet. ?? In Australia, fridges are measured in litre size. IE/ a fridge with say a model of HE550 would suggest 550 litres ( a reasonably big fridge)
Apr 09, 2015 | Refrigerators
What size is the glass shelf in a consul 8 cu ft propane fridge
measure the space with a tape measure or order by model number :-)
Aug 18, 2014 | Refrigerators
Whirlpool 6wmv43ns/02 Fridge Too Cold & Freezing Food
I would first try replacing the control in the fridge. If that doesn't remedy the situation, I would try replacing the thermostat next.
May 14, 2012 | Whirlpool Refrigerators
I live in hurricane ally and was wanting to run a dorm size fridge and some fans if needed, will a 3750 accomplish this?
you wil need at least twice the watts to start your fridge if you dont the compeser wont start and it will burn out just check the watts on the fridge good luck
Aug 23, 2011 | Briggs & Stratton Power Products 5,550...
Frozen evaporater line, water leaking into fridge, food freezes at back of fridge
Check for the evaporator passage. Its when the passage gets block it started leaking to the fridge. It should be just below the freezer. Defrost the freezer an try to manually clean the small passage (of a small pipe size). It may be frozen with water or clogged with dirt.
Mar 21, 2010 | Refrigerators
I just bought a RoadPro 2500 and i want to buy like a dorm fridge how many watts or volts size would work??
If you are referring to the RoadPro RPPI-250
  • 2000 Watts Continuous Power
  • 2500 Watts Power Output @ 10 Minutes
  • 5000 Watts Peak Power Output.
  • A small fridge will use about 500 -700 watts, with startup wattage at around 2000watts.
  • So, a dorm fridge will work fine.
  • the RoadPro converts DC to AC voltage, so a regular 120 volt dorm fridge will work.
  • Jul 05, 2009 | RoadPro RPPI-2500W Inverter
    What size star key do I use to take off the fridge doors of model MTX18BAXJRWH?
    The torx T-20 is generally the size needed for fridge hinges. That said, I recommend that you purchase a set of these star [torx] screwdrivers, then you will have what will soon become a most common screw in the industry.
    Jun 14, 2009 | Refrigerators
    Repair lining of fridge
    depending on the size of the hole you can use white rtv silicone or white epoxy
    Feb 09, 2008 | Refrigerators
    Refrigerators Logo
    15 people viewed this question
    Top Kelvinator Refrigerators Experts
    John Tripp
    John Tripp
    billconfused
    Are you a Kelvinator Refrigerator Expert? Answer questions, earn points and help others
