Question about Sony KV-27S65 27" TV
Low audio output all of a sudden
Was working just fine. Now low audio even with it turned up all the way.
I connected pc speakers to the audio out rca jacks and that works.
All inputs have low audio output.
There also  seems to be slight  "moire"  swirl lines on the screen now too.
I had a similar problem and opened the box and blew out a ton of dust. Still don't know what the problem was, but the sound came back.
Posted on Feb 10, 2008
My RCA TV audio is very low
Check its speaker first. Test with an other speaker. If the fault perists, check the audio output circuit. Replace all the electrolytic capacitors there.
Aug 22, 2012 | RCA TruFlat 27F520T 27" TV
Rca tv ..how to hook up to home speakers
Unless the set has actual audio outputs it should not be done.
The set will have a very low audio output not intended for external systems--if you hook to wrong impedance speakers volume either will not work, be very low or even damage the audio circuit in the set
Mar 28, 2012 | RCA 27V530T 27" TV
Hi i have fusion sub woofer can u help me to install just let me know how to install many wires so dotn know who to install in my car
  1. Batt + or B+ or Positive.
    This is the connection directly to your automobiles battery. It should be a fused connection rated to about 15% higher than the fuse installed in your amplifier.
  2. Negative or '-' or Ground.
    This wire should be just as thick as the 'Batt + or B+ or Positive' wire. This wire can attach to any solid clean metal connation in the vehicle. Usually a trunk latch.
  3. Remote or amp startup wire.
    This wire is a thin 12V wire that will come from the deck. It's a signal wire that tells the amplifier to turn on.
  4. Inputs
    Low level inputs are in the form of RCA connectors and will require that your deck or head unit has low level or RCA outputs. High-level inputs are used for stereos that don't have low level or RCA outputs. They work by taking an audio signal directly from the vehicles speakers and then amplifying it as necessary.
  5. Speaker connection.
    Match the + and - these with the appropriate connectors on the speaker box. Red means + and Black means -.
    I hope this helps.
Jul 06, 2009 | Fusion FEW12PK Car Subwoofer
I have a white female rca and a red female rca which means right and left speakers hanging out of the back of my car audio cassette player. i can't anything out of them, nor can i get anything to go...
Hello joebobstgeor,
I wasn't able to lookup a manual for the Sharp GB960. In fact, manuals for any Sharp car audio product was woefully absent.
Try connecting the cables to the input of an amplifier. Female RCA jacks are used for low-level (preamplifier) outputs for subwoofers, sound processors, and additional amps. The impedance of the output is typically in the 20-25Kohm range and would not produce any sound in speakers or even low impedance headphones.
It's also possible that the RCA cables are an "AUX" input to the receiver and not an output. Although many of the mobile audio manufacturers are now using front-mounted phone mini-jacks as "AUX" inputs, some still have rear mounted RCA's.
Hope this helps.
May 18, 2009 | Sharp Car Audio & Video
No audio output from jvc cd receiver kd-sx770
The internal amplifier is at fault.
This will need to be repaired by a electronics repairman.
There is no end-user fix.
You may choose to, instead, use the RCA low level outputs and install a dedicated amplifier to power your speakers.
Verify the fuses on the radio are good, and that there is not a blown speaker causing the internal amplifier to shut down.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 20, 2009 | JVC KD-SX770 CD Player
Want to connect my RCA sub to my yamaha htr-5940 reciever
Subwoofer needs to be enabled through menu on Yamaha. LINE OUT might be turned off or Subwoofer volume set to low or off... (-db level) kinda thing...speaker wires are usually always live etc...
Feb 03, 2009 | Yamaha HTR-5940 Receiver
Rca jacks for external speakers have no output
rca jacks are a low level output. you have to use an amplifier with rca's. you cannoy hook rca's directly to speakers.
Jan 19, 2009 | Pioneer DEH-P3900MP CD Player
75-822 cb that has extremely low audio output
Hello..if you can try to connect a external speaker or phones..if the volume is ok..than i think it is time to replace your internal speaker..pse tll me....good luck...Ron
Mar 14, 2008 | Midland 75-822 40-Channels Handheld CB...
No sound through speakers
are you using RCA outputs(the round red and white plugs)? if you are then your amp is not turning on and if you are hooking up speakers to your RCA's (low level) then you will not hear any audio the signal is to low. would need to know more about how you checked the ic power?? one could verify an output ic by hooking up an amp since the RCA audio signal is picked off just before the output. if the low level works but the speakers do not then you have a bad output. anything else an o-scope would be handy.
good luch stereo tech (genesisportland@hotmail.com)
Feb 03, 2008 | Alpine CDE-9881 CD Player
Subwoofer connection
if this is ao powered sub, that plugs into the wall, there should be no problems, if it is powered solely by the reciever it may work fine but be sure you dont exceed amperage on the subwoofer.
Jan 28, 2008 | Bose 151SE Main / Stereo Speaker
Sony KV-27S65 27" TV Logo
80 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
