Question about Naxa NID-7006A Core 7" Tablet Computer, A13 Cortex A8-1.2GHz, 512MB RAM, 4GB Built-in Flash Memory, Android OS 4.1
My tablet is stuck on a screen that says ANDROID
My tablet is stuck on a screen that says andoid and it wont switch even when I reset it
Wont boot up .Frozen stuck on screen
Corrupted firmware.
Just try a reset first. Switch OFF the tab: Take out the battery, re-insert it after 10 minutes or so. This must reset it.
Jun 18, 2015 | Tagital Tm 9" Android 4.0 Tablet PC...
My tablet wont come on. whenever i turn it on it just comes to the loading screen and says system loading. then it wont go any further its stuck on the loading screen. what's wrong it?
Sounds like a previous update did not finish installing due to being switched off in mid stream or it got corrupted.good news is you can reset android tablets to factory settings...bad news is you will lose all you settings and apps which you will need to reinstall once it is up and running.most tablets reset in the same way.
switch off ...then whilst holding the up volume and the home button hold down the power button then continue holding just the vol up and home button.it will display the robot then you can let go of all the keys and follow on screen instructions to reinstall factory reset.
some tablets are a little bit different to reset...instead of volume up its volume down.if you google your make and model of tablet it will describe correct procedure...one last thing...do not panic if it doesn't reset first time...some Chinese based tablets may take two or three attempts to reset.
Jun 11, 2015 | Tablets & eReaders
How to an lock my tablet forgot passwort
Someone else asked the same question. I copied and pasted the answer to save it for myself. (This is _not_ my answer. I am quoting the technician who gave it, including her name).
Note: This ''should'' work regardless of manufacturer. It is an ''Andriod'' thing.
Andoid cell phone reset
Here are the steps to perform a hard reset in your device:
1. Switch off the device.
2. Now press and hold Volume Down + Volume Up + Power button, and release them, when you see menu of Bootloader Mode.
3. Then select option "Recovery" from the menu, using Volume Down, then press Volume Up.
4. When you see Android with triangle, then press together Volume Up + Volume Down.
5. After that select option "wipe data / factory reset" using Volume buttons to browse option, and Power button to confirm operation.
6. Choose option "Yes -- delete all user data" and accept with Power button.
7. Press Power button to select option "reboot system now".
Best Regards,
Katy
Motorola Support
May 18, 2015 | Irulu iulu 10.1 inch Andoid 4.0 Touchcreen...
How do I reset my Zeepad 7.0 tablet to factory settings?
1. Power of the device.
2. Now,Hold down both volume+ and power button simultaneously, you should get an android on its back opened.
3. Press both volume + or - to open up a small blue text menu.
4. Then use Vol - and Vol + to navigate the Recovery mode.
7.)Select "Factory Data Reset", press power, choose "yes" from the menu then press power again.
Aug 10, 2014 | ZeepadTM 7" Zeepad 7.0 Andoid 4.0...
How do I fix a blue screen on my zeepad jelly bean tablet
See this site... http://www.howtogeek.com/130611/how-to-factory-reset-your-android-phone-or-tablet-when-it-wont-boot/
Jun 30, 2014 | ZeepadTM 7" Zeepad 7.0 Andoid 4.0...
The tablet wont charge
I have a Pandigital Google Android Planet 7" touchscreen tablet with andoid 2.2 os 2Gb.The glass under the screen broke can it be the place?
Aug 15, 2013 | Mach Speed Trio Stealth G2 Tablet -...
Start up stuck on yes optus screen
You maybe able to RESET the tablet.
There maybe a pinhole RESET button on the back of the tablet. Insert a straighten paper clip into the pinhole RESET button to reset the tablet.
Mar 31, 2013 | ZTE V9 Smartpad Android Internet Tablet
I locked my pink zeepad 7.0 andoid tablet. how do i reset it i can't find a reset button
look for a small hole in the back it will say reset insert a pin into hole to reset
Jan 29, 2013 | Tablets & eReaders
Naxa NID-7006A Core 7" Tablet Computer, A13 Cortex A8-1.2GHz, 512MB RAM, 4GB Built-in Flash Memory, Android OS 4.1 Logo
41 people viewed this question
Top Naxa Tablets & eReaders Experts
Are you a Naxa Tablet and eReader Expert? Answer questions, earn points and help others
