Question about Dee Zee 2003 Chevy Silverado - 1500, LS - Euro Grille Guard
Having an alpine cde-141 stereo and alpine sps-610c speakers how to hook the speakers to the unit individually the way the factory has them or like on the wiring diagram for amplifier on the box
How to hook up the speakers with both hook ups or one run through the bass speakers
Where can I find the audio diagram of this scar stereo
90% of stereo wire harness are the same colors, so here you gohttp://columbiaisa.50webs.com/car_audio_typical_hu_wiring_colors.jpg
Jul 14, 2015 | Alpine CDE-141 CD/MP3 Car Stereo Receiver...
Dan alpine sps- 610C speakers be installed in a 2011 sonata
as long as they fit in the hole..u good..whether or not your radio can thump em?...mabe you can add an amp later
Jan 08, 2014 | Car Audio & Video
I just bought the aux cable to connect my I phone 4 to my cde-9881 alpine stereo but when I hooked it up my iPhone connects to the head unit but only plays music thru the speaker on the phone. Why??
try playing your music first on your phone then with the cord alreay in your radio, plug it in to your phone....If that doesnt work, might be a setting on your radio....is it on aux in????
Mar 17, 2012 | Alpine Car Audio & Video
Alpine 9845 cde head unit car stereo i Cannot figure out how to access the Fader not the balance,altho i havent seen that function either. ive been to the alpine site and they dont even mention it. im sure...
Press the Rotary encoder (CDE-9845/CDE-9843
only) or press MODE (CDE-9841 only) repeatedly
to choose the desired mode.
Each press changes the modes as follows:
BASS → TREBLE → SUBWOOFER* → BALANCE → FADER
→ DEFEAT → VOLUME → BASS
BASS: -7 ~ +10
TREBLE: -7 ~ +7
Subwoofer : 0 ~ +15
Balance : L15 ~ R15
Fader : R15 ~ F15
Defeat : ON/OFF
Volume : 0 ~ 35
Feb 11, 2010 | Alpine CDE-9845 CD Player
I have a 04 silverado do i need to install my component speakers in series or can i hook up woofer to factory wing and tweeter seperate from factory
With component speakers it is imperative that both the speakers be hooked up to the supplied crossover. Wiring them in series or parallel will not yeild satisfactory results since the woofer requires lower freequency then the tweeter, which plays the high notes.
Now some cheaper speakers do not use crossovers and sound rather poor. What make and model of speaker are installing? Does you truck already have component speakers in it?
Cheers,
Jan 06, 2010 | Alpine SPS-600C Car Component System
Want to know if the alpine sps 13c2 5.25" would fit a 2001 dodge durango with infinity speakers
from what i can find it says if its the back door speakers then the factorys are 6 3/4.u could either make brackets or buy sum.hope that helps
Oct 13, 2009 | Alpine (SPS-13C2) Coaxial Car Speaker
I am getting a DC error on my alpine cde-102 head
Hello christo12385,
The DC error is most likely caused by a shorted or grounded speaker wire. Check all speaker wires, correct the problem, and then go into the sound setup settings and reset the POWER IC to ON.
Hope this helps.
Sep 25, 2009 | Alpine Car Audio & Video
After installing the alpine CDE 9870 car stereo there was no sound... although the car speakers work.Maybe the audio in the stereo?Can thatbe fixed?
In this situation 8 times out of 10 the problem is not with the radio, it's that there are factory amplifiers. Many cars have them, and most require a little work, or an adapter to get going. Tell me the year, make, and model of the car, and perhaps I can give you more info.
Aug 09, 2009 | Alpine Car Audio & Video
Dee Zee 2003 Chevy Silverado - 1500, LS - Euro Grille Guard Logo
Top Dee Zee Wine & Spirits Experts
deton8 von Splosion
Dave braun
Dave braun
guymark
Level 1 Expert
Are you a Dee Zee Wine and Spirit Expert? Answer questions, earn points and help others
