Question about Individual ResumeMaker Professional 15 for PC
When I was installing Resume Maker 15 I had a problem
It showserror1609. An errror ocurred while applying security settings.
BUILTIN\Users is not a valid user or group. This could be a problem with the package or a problem connecting to a domain controller on the Network connection and retry.
I installed well in my desktop which has Microsoft Windows in english but I need to installed in my computer which has Microsoft Windows in Spanish, could be this the problem, how can I fix it? Please help me I need it now to be installed in my laptop.
I cant install service pack3 for win xp because error 0x800a0046
Try this method
* Remove the user account that is experiencing difficulty from the Guests
or Limited account groups
Click Start, click Run, type control admintools, and then click OK.
Click Computer Management.
Expand Local Users and Groups.
Select Users.
Open the account that is used to access Windows Update.
Click the Member Of tab.
Select the user account that you want to remove, and then click Remove.;
* Add the Local Administrator and Service accounts to the Impersonate a
client after authentication policy
Click Start, point to All Programs, point to Administrative Tools, and
then click Local Security Policy.
Expand Local Policies.
Click User Rights Assignment.
Double-click to open the Impersonate a client after authentication
policy
On the Local Security Settings tab, click Add User or Group, and then
add the Administrator and Service to the list of Users and Groups.
Click OK, and then restart the computer.
good luck
Jun 27, 2011 | Computers & Internet
Tip
How to solve Internet Explorer 8 installation problems
Method A: Reset Windows security settings back to the defaults
Restore the security settings to the default settings.
To fix this problem automatically, click the Fix this problem link which is in the article 949220 Then click Run in the File Download dialog box, and follow the steps in this wizard.
1. Click Start, click Run, type cmd, and then press ENTER.
2. In Windows XP, type the following command, and then press ENTER:
secedit /configure /cfg %windir%\repair\secsetup.inf /db secsetup.sdb /verbose
In Windows Vista, type the following command, and then press ENTER:
secedit /configure /cfg %windir%\inf\defltbase.inf /db defltbase.sdb /verbose
You receive a "Task is completed" message and a warning message that something could not be done. You can safely ignore this message. For more information about this message, see the %windir%\Security\Logs\Scesrv.log file.
Next steps After you run this Microsoft Fix it (or complete these manual steps), standard user accounts may no longer appear on the log on screen when you start your computer or try to switch users. This occurs because standard user accounts are removed from the Users group when you reset Windows security settings. To add the affected users accounts back to the Users group, follow these steps:
1. Click Start, and then All Programs. Or click Programs.
2. Click Accessories, and then click Command Prompt (Windows XP). Or right-click Command Prompt, and then click Run As Administrator (Windows Vista).
3. In the Command Prompt window, type net users and then press ENTER. A list of user accounts is displayed.
4. For each accountname listed in the Command Prompt that is missing from the log on or switch user screen, type the following command and then press ENTER:
net localgroup users accountname /add
5. Now go to the "Did this fix the problem?" section.
Note In Windows Vista, the Defltbase.inf file is a Security configuration template for the default security. You can view the settings for this file in the following location: %windir%\inf\defltbase.inf
For online Help about Secedit, click Start, click Run, type %windir%\help\secedit.chm, and then press ENTER.
Advanced troubleshooting
Method E: Check for any files that cannot be backed up or updated
This method is rated: Moderately difficult.
To complete this method, follow these steps:
1. Determine whether a problem is preventing the files from being backed up or updated. To do this, follow these steps:
a. Click Start, and then click Run.
b. Copy and then paste (or type) the following text in the Open box, and then click OK to open the ie8_main.log file:
%windir%\ie8_main.log
Note By default, the ie8_main.log file is located in the C:\Windows folder.
c. Press CTRL+END to move to the end of the ie8_main.log file.
d. On the Edit menu, click Find.
e. In the Find what box, type ArchiveFileForUninstall:ArchiveSingleFile Canceled.
f. Under Direction, click Up, and then click Find Next.
If you find the "ArchiveFileForUninstall:ArchiveSingleFile Canceled" text, this indicates that there is a problem that is preventing an Internet Explorer 8 file from being saved for removal. For example, text that resembles the following in the log file indicates that a problem exists:
Time_stamp: ArchiveFileForUninstall:ArchiveSingleFile Canceled
Time_stamp: DoInstallation:UpdSpCommitFileQueue for AlwaysQueue Failed: 0x4c7
If you do not find the "ArchiveFileForUninstall:ArchiveSingleFile Canceled" text in the ie8_main.log file, contact Support.
2. Reset the permissions for the Vgx.dll file. To set the permissions of the file to the default settings, click Start, click Run, type cmd, and then click OK. At a command prompt, copy and then paste (or type) one of the following commands, and then press ENTER:
o If you are running Windows XP, copy and then paste (or type) the following command:
echo y| cacls "%CommonProgramFiles%\Microsoft Shared\VGX\vgx.dll" /P BUILTIN\Users:R "BUILTIN\Power Users:C" BUILTIN\Administrators:F "NT AUTHORITY\SYSTEM:F"
o If you are running Windows Server 2003, copy and then paste (or type) the following command: echo y| cacls "%CommonProgramFiles%\Microsoft Shared\VGX\vgx.dll" /P BUILTIN\Users:R "BUILTIN\Power Users:C" BUILTIN\Administrators:F "NT AUTHORITY\SYSTEM:F" "NT AUTHORITY\TERMINAL SERVER USER:C"
3. Try to install Internet Explorer 8. If Internet Explorer cannot be installed, contact Support. If the log file shows a problem, repeat all the steps in this method. If you repeat the process, and Internet Explorer 8 still cannot be installed, but the log file is clean, contact Support
on May 03, 2010 | Computers & Internet
Tip
Using UAC in Windows Vista
Windows Vista has the built-in ability to automatically reduce the potential of security breaches in the system. It does that by automatically enabling a feature called User Account Control (or UAC for short). The UAC forces users that are part of the local administrators group to run like they were regular users with no administrative privileges.
Although UAC clearly improves the security on Windows Vista, under some scenarios you might want to disable it, for example when giving demos in front of an audience (demos that are not security related, for example). Some home users might be tempted to disable UAC because of the additional mouse clicking it brings into their system, however I urge them not to immediately do so, and try to get used to it instead.
Anyway, if required, you can disable UAC by using one of the following methods:
Method #1 - Using MSCONFIG
  1. Launch MSCONFIG by from the Run menu.
  2. Click on the Tools tab. Scroll down till you find "Disable UAC" . Click on that line.
  3. Press the Launch button.
  4. A CMD window will open. When the command is done, you can close the window.
  5. Close MSCONFIG. You need to reboot the computer for changes to apply.
You can re-enable UAC by selecting the "Enable UAC" line and then clicking on the Launch button.
*Recommended: Speed up Vista boot times by reducing the number of programs that load at startup. Control your Vista startup list with this Vista app
Method #2 - Using Regedit
  1. Open Registry Editor.
  2. In Registry Editor, navigate to the following registry key: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies\System
  3. Locate the following value (DWORD): EnableLUA and give it a value of 0.
    disable_uac_2.gif Note: As always, before making changes to your registry you should always make sure you have a valid backup. In cases where you're supposed to delete or modify keys or values from the registry it is possible to first export that key or value(s) to a .REG file before performing the changes.
  4. Close Registry Editor. You need to reboot the computer for changes to apply.
In order to re-enable UAC just change the above value to 1.
Method #3 - Using Group Policy This can be done via Local Group Policy or via Active Directory-based GPO, which is much more suited for large networks where one would like to disable UAC for many computers at once.
If using Local Group Policy you'll need to open the Group Policy Editor (Start > Run > gpedit.msc) from your Vista computer.
If using in AD-based GPO, open Group Policy Management Console (Start > Run > gpmc.msc) from a Vista computer that is a member of the domain. In the GPMC window, browse to the required GPO that is linked to the OU or domain where the Vista computers are located, then edit it.
  1. In the Group Policy Editor window, browse to Computer Configuration > Windows Settings > Security Settings > Local Policies > Security Options.
  2. In the right pane scroll to find the User Access Control policies (they're down at the bottom of the window). You need to configure the following policies:disable_uac_gpo_2.gif
  3. You'll need to reboot your computers.
Method #4 - Using Control Panel
  1. Open Control Panel.
  2. Under User Account and Family settings click on the "Add or remove user account".
  3. Click on one of the user accounts, for example you can use the Guest account.
  4. Under the user account click on the "Go to the main User Account page" link.
  5. Under "Make changes to your user account" click on the "Change security settings" link.
  6. In the "Turn on User Account Control (UAC) to make your computer more secure" click to unselect the "Use User Account Control (UAC) to help protect your computer". Click on the Ok button.
  7. You will be prompted to reboot your computer. Do so when ready.
In order to re-enable UAC just select the above checkbox and reboot.
on Apr 29, 2010 | Microsoft Windows Vista Home Premium...
Sound recording device disabled. enable of soud recording device
1. Open the all users, specific users or groups, or all users except administrators Local Group Policy Editor for how you want this policy applied.
2. In the left pane, click on User Configuration, Administrative Templates, Windows Components, and Sound Recorder. (See screenshot below)
3. In the right pane, right click on Do not allow Sound Recorder to run and click on Properties. (See screenshot above)
4. Close Local Group Policy Editor window. Your done
Jun 04, 2011 | Computers & Internet
Local policy of the system does not permit you to login
This is due to a security change in MS XP SP3. All you need to do is go to the Group Policy Security MMC and change the option to 'allow logon through terminal services'. By default, with SP3, the only users that are allowed to do that are members of the Administrators group and members of the Remote Desktop Users group. Another quick work around is to simply make your users members of the Remote Desktop Users group.
Sep 22, 2010 | NComputing X300 3 User Expansion Kit...
Tip
How to take ownership of a folder and Grant permissions in Win 7?
Summary:
Windows 7 has implemented addition security mechanism to prevent accidental or intentional file or folder modification by not allowing users other then owner of file or folder to access it. Hence incase if you need to access, modify or delete such files or folder you need to take ownership first then assign rights or permission to respective users. Here is Guide on How to take Ownership and Grant Permission in Window 7.
More Information:
How to Take Ownership in Windows 7?
  1. Locate the file or folder on which you want to take ownership in windows explorer.
  2. Right click on file or folder and select “Properties” from Context Menu.
  3. Click on Security tab.
  4. Click on “Advance” (For special permission or advance settings click advanced).
  5. Now click on Owner tab in Advance Security Settings for User windows.
  6. Click on Edit Button and select user from given Change Owner to list if user or group is not in given list then click on other users or groups. Enter name of user/group and click ok.
  7. Now select User/group and click apply and ok. (Check “Replace owner on subcontainers and objects” if you have files and folder within selected folder).
  8. Click ok when Windows Security Prompt is displayed.
  9. Now Owner name must have changed.
  10. Now click Ok to exist from Properties windows.
Once you have taken the ownership of file or folder next part comes is Granting Permissions to that file/folder or object.
How to Grant Permissions in Windows 7?
  3. Click on Edit button in Properties windows Click ok to confirm UAC elevation request.
  4. Select user/group from permission windows or click add to add other user or group.
  5. Now under Permission section check the rights which you want to grant i.e check “Full Control” under the “Allow” column to assign full access rights control permissions to Administrators group.
  6. Click Ok for changes to take effect and click ok final ok to exit from Properties window.
Now you can access files of folder in windows 7 with full permissions and take full control.
on Mar 26, 2010 | Computers & Internet
My desktop says that my computer did not pass genuine windows val
For Windows XP Home
Restart your computer and before the appearance of the boot screen hit F8 to get the booting option list. From the list select Safe Mode in order to start your computer in Safe Mode.
Once the computer has booted in Safe Mode go to Start > Run and type c:Documents and SettingsAll UsersApplication DataWindows Genuine Advantage (where C: is usually the system drive).
Right click the DATA folder and choose Properties. Now go to the security tab and in the Group or user names section click on Users. In the permission for user section make sure you check all the check boxes under the Allow column: Read & Execute, List Folder Contents and Read. Click OK and then restart the computer. Now you should be able to validate your Windows copy.
For Windows XP Professional
In Windows XP professional there is no need to boot in safe mode. Just go to Start > Run and type c:Documents and SettingsAll UsersApplication DataWindows Genuine Advantage. There you will find the Data folder. Right click on it and follow this path: Properties > Security tab > Users > Permission for users section and verify the Allow column for all the check boxes to be selected. If not selected, do it yourself.
Now restart the validation process.
for more help go here:
http://www.mydigitallife.info/2006/03/07/bypass-and-disable-genuine-windows-validation-check/
Mar 20, 2009 | Dell Dimension 4300 PC Desktop
Missing user names and groups from "Security settings" window
You have to backup all SYSTEM files and reinstall the OS. That's the ultimate solution to your problem.
Dec 26, 2008 | Microsoft Windows XP Professional With...
TERMINAL USER SECURITY IN WINDOWS 2003
please define users & give him restrictions as well as rights,
make them as an standard user (dont define them as an administrators) if u have some applications which have to be use by terminal users then give them only that much of applications..
dont allow them to use anyother applications..
May 03, 2008 | Microsoft Windows Server Standard 2003 for...
Individual ResumeMaker Professional 15 for PC  Logo
146 people viewed this question
Top Individual Computers & Internet Experts
john smith
gary433
Vebble
Are you an Individual Computer and Internet Expert? Answer questions, earn points and help others
