Question about AdobeAir Heating & Cooling
Mastercool ec 630 n
HOW DO I REMOVE THE OLD PADS?
Mastercool doesn't seem to be getting enough water circulating
If the pads are old replace them. Take a panel off and look at the water dist. tubes if plugged, best method to remove it and use compressed air blow from the center, and let it rip, the basket maybe dirty. Good luck
Jul 02, 2011 | Mastercool 67471 Evaporative Cooler Air...
I am a single woman trying to prepare my mastercool for winter. I don't know how to remove the pads, so if insructions could be sent, it would be greatly appreciated. I don't know the size of the cooler,...
Is it a side draft or downdraft cooler? My instructions simply say to cover the unit, disconnect the power and drain the water for winter. They don't suggest removing or cleaning the pads until spring. If you're ductwork also is connected to your furnace, and you don't have a cookie sheet(piece of sheet metal that fits in a slot beneath mastercool unit or along the inside if it's a side draft cooler) then besides covering the entire unit you cn probably cover the blower, also called the squirrel cage, with a canvas cover.
Oct 09, 2010 | Mastercool 67680 Evaporative Cooler Air...
Need replacement pads for mastercool mrc55wa evaporative cooler
These pads are available in different sizes and styles at home improvement stores like LOWES or HOME DEPOT (in season)
Sep 18, 2009 | Mastercool 67471 Evaporative Cooler Air...
Mastercool pump runs when themostat is off.
Check the compressor relay (in the outside unit) Most likely it's stuck.
Sep 12, 2009 | Mastercool 67680 Evaporative Cooler Air...
Water pump size and over saturated pads
Louis, The cooling does not come from the volume of water running over the pads. It cools by cooling the air passing through the wet pads. So, Yours is an impeccably logical argument that leads to a false conclusion. Bigger is not better in this caThe fishy smell is from the matting (pads) when kept saturated, Molds and algae will form if there is too much water also.. Best you get the original size pump Good luck and stay cool - Ned
Jul 25, 2009 | Mastercool 67680 Evaporative Cooler Air...
We have a Mastercool II & it was installed ~ 3
The pads you need are at least 8 inches thick. If you have the contractor model, then the pads will be 12 inches thick.
Find a distributor in your town that sells cooler parts, if they dont have them, some of the big home improvement stores carry the pads for your cooler.
Make sure you are using a bleedoff or a dump pump to eliminate the hard water out of the cooler. If you keep those pads clean, they wiil last for many years.
Jul 20, 2009 | Mastercool 67680 Evaporative Cooler Air...
Summer
If it was not drained for winter, do so and then remove all scale from the pan, pump inlet screen, etc. Replace the pads if they are scaled up and remove any scale from the louvered panels. WITH THE POWER OFF, check the belt for cracking and check to drive motor and blower wheel bearings for smooth operation, oil bearings with oil ports. With clean water in the sump, a good drive belt, clean pump screen and clean pads, the unit is ready to power up and run test the float action/shut-off, water distribution through the arms, belt tension (just enough to prevent slipping). These units work best when they can fully evaporate the water, so let the air flow out as fast as it come into the cooled space to maximize the evaporative effect. Also note, these unit must be level to work properly.
Apr 27, 2008 | Mastercool 67680 Evaporative Cooler Air...
Heating & Cooling Logo
26 people viewed this question
Top AdobeAir Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you an AdobeAir Heating and Cooling Expert? Answer questions, earn points and help others
