Question about Canon LaserClass LC 8500 Plain Paper Fax
Replace feed tire Canon L770 fax
Replace feed tire
Scanner has been used for a few years, and is frequently pulling multiple items through at the same time. We have cleaned the rollers with alcohol wipes, and fed the waffle papers through to clean.
If this is a Canon CR-180 or 180II machine then the feed tires need to be replaced. Often if you are using the grey feed tires, the middle one will come loose from the platic hub and cause this problem no matter how much you tighten the tension wheel. The part numbers of the seperatrion roller assembly and the feed tire assembly are as follows.
MG1-3530-000 Seperation roller (has 3 tires)
MF1-4210-000 Feed roller (has 2 tires)
You can also replace the two in the hopper area, they are:
MF1-4352-000
MF1-4353-000
That is a common problem on older machines; hopefully that helps
Feb 24, 2011 | Canon CR-180
Canon Image Class MF5770 paper feed issue
2 possibilities. Your Document Feeder separation rollers need to be cleaned. You can clean them with a cloth and glass cleaner. Look for an assembly that looks like this:
Just rotate and clean the tires and see if that helps.
There is also a separation pad assembly that you might have to replace if it is worn out. It looks like this:
Both of these parts can be ordered from Precisionroller.com
I am not affiliated with them in any way. Just use them from time to time for parts such as these.
Good Luck
Dec 02, 2009 | Office Equipment & Supplies
Adf sporadically pulls fax/ copy through top
Yes,but the most imported part for dubble feeding is the sepatation pad,this white pad is on the lower part of the docfeeder and work with the feed rollers,fist make sure that pad is clean before you replace the rollers,and then replace the pad.
Jun 17, 2009 | Canon PC-1080F Plain Paper Laser Fax
Jams when you feed an original
You need to replace the black plastic holder that the ADF roller sits in as they wear and the holes get oblong shaped and cause the rollers not to operate correctly.
Mar 05, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Top feeder not working MF6550
One or both of the ADF hinges are bad. The ADF cover doesn't close all of the way causing feed failure of the original and shading on the side of the copy because the scanned original is not fully contacting the **** exposure glass on the front operators side.
Feb 27, 2009 | Canon imageCLASS MF6550 All-In-One Laser...
Does anyone know the difference between a canon ****** roller and an exchanger roller on a canon dr-2080c scanner? I am looking to replace the rollers that are ageing and now "picking" up more than one...
The exchange roller kit has all the tires that pick up the paper in the kit (feed, separation, and pick up tires). I think the other tire you are talking about is just one tire not the set.
Also check to see a switch on the scanner that is used for single feed or multiple feed. If its on single feed it will multi feed all the time. You can clean the tire with rubbing alcohol too, to see if your double feeding goes away.
Jan 25, 2009 | Canon DR 2080C Path-Through Scanner
Canon Laser Class 8500
Problem is caused by worn paper feed tire, and seperation tire. The worn tires causes vibration on the seperation plate. Replace both tires.
Dec 12, 2008 | Canon LaserClass LC 8500 Plain Paper Fax
Paper will not feed through - Samsung SF-4500c FAX
try isopropyl alcohol it may work for awhile depending on how smooth the tires are, you can replace them:
try this site
precisionroller.com
Aug 12, 2008 | Samsung SF-4500 Plain Paper Thermal Fax
Copying and fax sending problem
  1. Just check & clean the dust in the original feeding area.
  2. if not solved, clean the Document feed sensor or replace the same. But for this you need to open the body of the fax machine.
Mar 11, 2008 | Canon FAX-B820 Plain Paper Bubblejet
Canon LaserClass LC 8500 Plain Paper Fax Logo
20 people viewed this question
old marine
old marine
