Question about Ariens 34 In 344 CC Briggs Stratton Hydrostatic Zero Turn Mower
Cant get drive belt removed from a gravely mini zt
Need help removing drive belt from gravely mini zt 1534
  • Richard Wilson
    Richard Wilson Oct 10, 2014
    How did you get the belt off?
How do i replace the drive belt on a gravely zt 48xl?
I am not able to find a manual for the zt48 but looking at one for ZT50 should be similar. Refer page 29 for belt replacement after download from the link provided below.
If this is not same as your model then please post the serial number of your mover in the comments field.
http://lawnandgarden.manualsonline.com/manuals/mfg/gravely/915150_zt_50.html
Sep 23, 2014 | Garden
How to replace Drive belt for z60 gravely
remove the deck drive belt.
then crawl up underneath the engine and then you will see a tension arm. remove the spring tension and then you can remove the belt... reverse for installation... NO, it's not that easy but close
Sep 01, 2014 | Garden
How to tighten belts on a gravely zt 60HD zero turn lawn mower
Todays belts are not as good as the ones we once bought and tend to stretch out quickly and easily. More than likely you need to replace them.
Aug 23, 2014 | Garden
Gravely only clicks wont start but hour meter works
Sounds like a low battery, enough juice for the hour meter but not for the starter
Aug 14, 2014 | kawasaki 2010 Gravely Zt 42 Xl Zero Turn...
How to change the clutch on a gravely ZTR 260z. What keeps the clutch from spinning around on the engine shaft? A diagram of the clutch assembly would help. Instruction on removing and reinstalling might...
There is an "anchor" that bolts to the chassis, and it has a rod-like part that sticks up to engage a notch in the PTO clutch to keep it from spinning. Look here -- there are parts diagrams for your mower (find the right model number) that will help a lot. Good luck!
Jul 07, 2010 | kawasaki 2010 Gravely Zt 42 Xl Zero Turn...
Engine dies when Blade is engaged
It sounds like the seat safety switch is the problem. Tilt up the seat and make sure the plug to the seat switch isn't loose or off completely, and that the switch is firmly mounted. If everything seems ok, remove the switch and test it with a multimeter. The circuit between the switch terminals should close when you press in the button. If not, replace it. Good luck!
Jun 04, 2010 | kawasaki 2010 Gravely Zt 42 Xl Zero Turn...
Ariens 34 In 344 CC Briggs  Stratton Hydrostatic Zero Turn Mower Logo
59 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
