Question about Cobra 8000 Pro HD GPS Navigation Device
Navigation keeps locking up how do I do a mater restart
GPS keeps locking up
Have a tomtom xxl its getting power then goes to the screen this device belongs to me n has a button to press continue but when I press it just stays there and doesn't load into the sat nav menu
Have you tried to "re-boot" your device ? e.g. hold down the ON/OFF button for a (long) while ... until the device shuts down and restarts ... (and see if it goes past that point)
Or have you tried to do a "hard" reboot, by pushing a pin into the RESET hole (at the bottom of the GPS) to shut it down and restart it ?
If both of these doesn't work, it may be a (navigation) software error. In this case, try to restore your navigation software from your (latest computer) back-up ... and see if that solves the problem.
if not, you may have to get TomTom support's help to download a "fresh" version of your navigation software to install on your GPS device, and then try to start it up ...
Jul 16, 2016 | Tomtom XXL GPS
Keeps beeping and displaying approaching turn
The "Approaching Turn" message is coming from an active navigation on your device. To turn it off, press and hold on the left side of the bezel (GPS), then press the lap/reset/quit key to exit the compass screen. You should then be in the GPS menu. There should be an item in this menu titled "Stop XXXX" where XXXX is "Navigating", or "Back to Start", or something like that. Select that option, and it should stop the navigation, and eliminate the "Approaching Turn" messages.
Sep 29, 2013 | Garmin Forerunner 405 Handheld GPS...
One unable to restart
Software is corrupted. See if Tom Tom has software for you to recover your system.
Sep 11, 2017 | Tomtom ONE XL GPS
My gps, when turned on says in a different language, ''das system kann die navigationssoftware nicht im dpeicher finden, bitte uberpufen und system neu starten'' and it will not let me do anything.
This is German language and says: 'The system cannot locate the navigation software in the memory. Please check and restart.'
Your unit is blank. You need to reinstall the navigation software.
Jan 02, 2010 | GPS
Change time
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>- --> --> Question Setting the clock Answer To select the type of clock that is shown and set the time, tap Change preferences > Set clock.
This feature is only available on your navigation device. You cannot use this feature in TomTom HOME.
  1. The easiest way to set the time is by tapping the Sync button. Your navigation device will then take the UTC time and date from GPS information.
    Note: You can only use Sync if you have GPS reception, so you cannot set the clock in this way when you are indoors.
  2. Adjust the hours depending on your time zone. Your navigation device works out your time zone and always keeps the time correct using GPS information. You only need to adjust the daylight-saving time.
Nov 10, 2009 | Tomtom ONE XL GB Car GPS Receiver
Navigation portion of the software blocked
Did you ever figure it out? Because I have the same problem
Jun 06, 2009 | Digi MAXX tal Media Explorer I Car GPS...
STOCK IN ONE POSITION
Try a GPS reset, exit navigation, click on setup, click on GPS reset. then restart navigation. check the gps status screen to make sure you are getting signals. if not, you could have a failed antenna or GPS receiver in the unit.
Jan 26, 2009 | Fine Digital FineDrive 400 GPS Receiver
Unit says " waiting for signal"
Unlocked. Otherwise your unit will freeze during Navigation (it needs the free space on the SD Card to run DATA)
Nov 05, 2008 | InVion 5 GPS Navigation
Navigation screen switches to menu screen w/out touching it
go to MENU --> SETTINGS --> DISPLAY --> there u can switch off the navigation key icons.
May 25, 2008 | Tomtom GO 720 GPS Receiver
Gps fail to reconize location
exit navigation, from the main menu select GPS reset, then restart navigation. if you do not get signals, you may have a failed antenna...
Apr 05, 2008 | Fine Digital FineDrive 400 GPS Receiver
Cobra 8000 Pro HD GPS Navigation Device Logo
50 people viewed this question
Top Cobra GPS Experts
Steve
TO Lady
Are you a Cobra GPS Expert? Answer questions, earn points and help others
