Question about Samsung UN55ES7500
Where is the hdmi port on the back of samsung un55f7500
I have a samsung dvd player with its hdmi cord but where is the hdmi connection on the back of the samsung tv un55f7500
  • 93 Answers
SOURCE: Samsung HDMI issue
Have you try to replace your HDMI cable?I recommend you to pick up a good Monster HD700 HDMI cable from a local retail store like best buy or circuit city.In case it isn't the cable problem,you could return it.
However,when you are a using the HDMI cable,it is normally either have both picture and sound or nothing at all.Are you sure you didn't hook up the audio OUTPUT from your TV back to a receiver input?
Or even an optical output from the TV to the receiver?
solutiondoct
Posted on Nov 06, 2008
SOURCE: Samsung DVD-SH855 DVD Recorder 250GB HDD playback freezes
Hey New firmware available for this "Timer issue" from Samsung and it works for me.
New firmware version - 080610.
Just ring Samsung and find out. They can advise nearest service cnter to do this.
Posted on Feb 13, 2009
SOURCE: digital - Weak or no signal digital coax when hdmi dvd player on
if u have placed your DVD next to your tv ... just maintain distance between then and check out
Posted on Apr 01, 2009
  • 57 Answers
SOURCE: No sound on my Samsung tv when I use a HDMI cable
hello..try to change the sound settings to HDMI..you say when you use other cables everything is fine so the TV reconizes the HDMi as a video only so your sound settings should be changed to HDMI
Posted on May 26, 2009
SOURCE: Samsung LN-R408D - No Picture
My Mom's LNR408D also had sound but no picture. I was able to fix it by soldering in a jumper wire across a blown (1.5A ???) SMD picofuse on the "T-Con" board.
Consider attempting this ONLY if you: 0) Know enough to avoid the potentially fatal High Voltage parts of the power supply board!!!
1) Are a fearless hackazoid 2) know what you're doing with a soldering iron and teensie SMD parts 3) are gonna throw the busted thing out anyway so you have nothing to lose and won't be sad if you screw something up.
4) Know enough to avoid the potentially FATAL High Voltage parts of the power supply board!!!!!
This board is at the top center under a close fitting RF shield. The suspect part was labeled "CP" on the board and marked with "P" on the part. It is visible above the right-center of the connector from the main board. An ohmmeter showed it as open, so I bypassed it with a jumper wire from connector VIN to the hot side of C13. One image shows the suspect part and the jumper in place.
The other shows the TCON board placement top-center (under its RF shield). With care, it seems possible to test the fuse and put the jumper in place without removing the shield. (Obviously don't touch anything else with the VOM leads!)
Thanks to ZORBUS and Steve's TV and Electronics for the idea.
http://www.avforums.com/forums/lcd-televisions/892447-no-picture-but-got-sound-my-samsung-lcd.html
http://www.gesda.com/transformer/Fall08_files/Page336.htm
Steve C
Posted on Sep 22, 2009
The coax input on my tv is broken off how can I connect the cable to it other than the red white and yellow cords which don't have a good connection either I have my dvd player hooked up to hdmi is there a...
the simple answer is no.
but if you have basic cable (coax) you could connect it to a vcr, tune the channels with the vcr-
connect the vcr to the TV with composite video (yellow, red/white)
Apr 13, 2011 | Samsung Televison & Video
How to hook updvd player to tv set
if the dvd player has hdmi connection use that.
if the TV has hdmi input use that.
if you can do both of these then use the TV remote to switch input to hdmi when the dvd player is on.
as an extra you can use toslink optical or coaxial digital cable from TV to home theater receiver for surround sound.
Jan 02, 2010 | Olevia LT37HVS 37 in. LCD HDTV
My HDMI connection does not work with Blu Ray DVD player. I have tried a Sony (BDP - BX2 ) model and Samsung (BD-P1590). It could not even display the Home screen for the Sony. The Samsung played for 1 day...
After reading your post a couple of times, it just seems your are in a little of a pickle here. The only thing I can suggest, since your tv will work with fios and not the your BD player(I assuming your using the same port on the tv with the same hdmi cable), is all about firmware. Maybe your tv is not compatible with the the BD player. Try updating the firmware on the tv.
Dec 30, 2009 | Panasonic TH-42PX500U 42 in. Plasma...
I want to connect my denon 790 to my 5:1 surround, HDMI DVD player and HD samsung 55'' LCD. what cables do i need and where to put them. thanks
You will need 1 HDMI cable to link between your DVD player and the Denon,plug the HDMI cord into the HDMI port on the back of your DVD player and the the other end into the Denon 790 HDMI port labeled DVD,then you will need another HDMI cord to go between the Denon and your LCD TV,plug one end of the HDMI cord into the Denon 790 HDMI port labeled HDMI monitor out and the other end into one of the HDMI ports on the back of your TV, it doesn't matter which one you use, just remember that you will have to change the input on the tv to that specific HDMI port when you play back a DVD and you will also have to change the Denon to DVD as your source to send the audio through the Denon to your surround sound speakers.( The Denon owners manual will help!!)
Nov 26, 2009 | Audio Players & Recorders
Need to connect dvd player have yellow, red and white connectors
Red is right channel, White is Left Channel, and Yellow is video.  If you just got the TV and DVD player its a pretty simple setup.  Just look on the back of the DVD player and hook the yellow cord to video and hook the other end to video on your TV.  Now just plug in the red and white cords to the audio on the back of the DVD player and connect the other ends to audio on the back of the TV.  You can bypass these connections and just get a HDMI cable which has video and sound all in one convenient cord, but they cost more.  You just connect the cord on the back of the DVD player where it says HDMI and then plug the other end to the TV where it says HDMI.
Nov 05, 2009 | Televison & Video
Compatibility with Samsung LCD Display
It sounds like the HDMI port on the back of your Marantz is damaged. if you know for sure that the HDMI port works on another tv still you might just use component connection because the visible difference between component and HDMI is not very recognizable.
Jan 13, 2009 | Marantz DV4001 DVD Player
HOW TO CONNECT HDMI DVD TO PS50Q97HD
With the power to both devices off, plug one end of HDMI into the DVD player output and the other to one of the two HDMI ports on the back of the TV or the port on the side. Power the TV on first then the DVD player. Now you will need to use the input button on the remote to find the correct HDMI port you plugged into on the set. When you find the correct input the screen displayed will have the screen that is displayed when there is no dvd in the player- that is unless you have one in at the time.
Hope this helps you out.
Sep 11, 2008 | Samsung Televison & Video
Compatibility Issue with HDMI Switch?
anytime your talking about a switch your talking about a temporary connection. The issue with using a switch is that for HDMI you want best quality and you will not get that using a temporary connection. The unit may be recognizing a weaker signal and turning the port off. However since the output on that particular unit is 1080i you should be fine using composite, just get a nicer monster set.
Dec 26, 2007 | Samsung DVD-R135
No Audio
What port do you have the HDMI from you BD player into on the 510. If you have it on the DVD port then fiber optic will do you no good, the DVD HDMI only supports digital coax, the Video2 HDMI only accepts fiber optic, and there is an extra fiber optic for the Sat input. If your BD player does not have digital coax out, or if you dont want to buy another cable, just move the HDMI from DVD to Video2 on the 510. I am willing to bet you have the BD player plugged into the DVD HDMI port and the fiber optic cable from you BD player to the Video2 fiber input.
Dec 18, 2007 | Sony STR-DG510 Receiver
Samsung UN55ES7500 Logo
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
