Question about Optics
Crosman problem gap on breach becase of brass band
My 2250xl gap under breach becase of the brass band
My church is looking for brass band instruments funding,but we don't seem to get one
.try lots of fund raising activities
using church hall and car park
church fete
baby sitting
games/movie nights ,
plays ./drama /choir nights
dances
cake auctions,
car washes
car boot sales
bingo ,
brass instruments are never cheap
you need to look around...for used brass instruments and brass sheet music
in second hand shops , garage sales , online sales newspaper ads
never knew any government or corporate companies to throw money into brass bands
Oct 18, 2016 | Music
Crosman 760 Pumpmaster air gun
You need to use a rod to knock out the stuck pellet. A brass rod, available at your local hardware store can be used to good effect. Use a small hammer to tap it out.
Jun 20, 2014 | Optics
Manual for protech band saw#3203
I found something on amazon, take a look here: Crosman Arms Company Model 140 147 147BP 1400 Rifles Owner Manuals Factory.... I hope this was helpful. cheers
Mar 03, 2012 | Saws
I need a service manual for crosman pell master 700 air rifle.
Here's the owner's manual: http://www.crosman.com/pdf/manuals/crosman/700/C700-OM.pdf
And a parts diagram: http://www.crosman.com/pdf/manuals/crosman/700/C700-EVP.pdf
Hope that helps.
Mar 05, 2011 | Sport & Outdoor - Others
Hello, i have a Crosman 760 Pumpmaster Air Rifle, i got it from my grandfathers basement and it does not hold air pressure, i dont know what year but its the old one with the brass bolt, not plastic. i...
Sounds like it has a bad o-ring. you can take it apart and replace the o ring for under a dollar. just make sure you look at how it goes back together when you take it apart they are very simple. just make sure the carefully take the right side cover off with the left side of the rifle laying on a table, everything should stay assembled this way so you can look at it. the part you are looking for is in the large chamber that the pump goes into. from the back (the side opposite the pump) remove the spring and the metal piece behind it, then use something the shove the big brass part out of the chamber and the o ring is on the big brass part . take the old o ring to a hardware store to get another one.
Feb 08, 2010 | Crosman (4032)
397 Ben/Sher .177 air rifle - installing repair kit problem
Crosman bought out benjamin / sheridan, and they still repair just all their pump guns. The ring sounds like a piece of a pellet, the barrels are silver soldered to the bottom tube, Not lead. Also, the repair kit should not have too many parts, you can only go so far with those guns before needing special equipment to get them apart. Get a hold of Crosman and tell them that benjamin sent you a bad part. They should fix it.
I had an old Benjamin Franklin in .22 cal, it was just a brass tube with a stock and barrel. I sent it to them, to be repaired, and I wanted the .22, because I had the 5mm and the 177. So I got it back, cost $29, New barrel, in .177, soldered on, new guts, new paint, trigger, bolt, the works.. Brand new gun. I told them I wanted the brass and I wanted the .22, They said oops, sorry. I didn't complain, nice old gun. Hope this helps.
Jul 29, 2009 | Crosman (4032)
Where can I purchase a Breach Seal for a Crosman Spring Air Rifle, Model C1K77? The Product # is C1K77-008. Also, Can I replace the worn out seal with a standard "O" ring (black) found in most hardware...
I don't know if you'll read this but I too Have a Crosman Phanton among other Crosman rifles. You can call Crosman at 1-800-7-AIRGUN for a free breech seal if your rifle is still in warranty (One Year) or e-mail me and I'll send you one at no charge. Don't worry I have several and don't have a problem with giving you one.
Mar 05, 2009 | Crosman Phantom .177 Caliber Break Barrel...
Optics Logo
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
