Question about Invacare Pronto M51 Power Wheelchair
I disconnected the battaries and can not figure out hoew i did it soo i can clean the battary box because my mpthers chair has been in the shed for a while and i wanted to clean it and that way she ca
Battery connections how they go back on or are connected
NO POWER AND NO DISPLAY
try without battary......
otherways... disconnect power jack and battary and all other cable connected to computer and press and hold power butten for 38 sec then try to power on
Nov 25, 2012 | Compaq Presario C700 Series Laptop...
My samsung gt s3650 switched itself off and now will not turn back on??
remove the battary make the battary clean and fix the battary properly and charge the battary if it will not effect then give the phone to a samsung delear
Jul 14, 2011 | Cell Phones
No reaction to RC signals. What lights are supposed to be on, on the remote?
Battary is may not proper charged.If you use this toy first time please reed menual for charging period of battary.
Jul 12, 2011 | Exceed-RC Exceed RC Brushless Pro SunFire
I have a big problim with mt 91 honda accord my battary wount charge i put new altanater new battary all cables are great but it wount seem to charge the battary if i charge the battary it well last up to...
With the engine running are you getting any voltage off the alternator? check with a multimeter. Check voltage at battery while running should be 13 volts or more.
May 16, 2010 | 1991 Honda Accord
Two weeks ago, when I went to Acura deller for oil change, they sugested me change the battery, since I never got a problem for start, so i did not change the battary. But next day I can not start my car,...
First make sure the terminal and posts are clean and greased.
Then make sure the alternator belt is tight.
The type of battery makes no difference as long as it fits.
What matters is whether or not the alternator is putting out 13.5 volts or higher, in order to keep the battery at 12.5 volts. Put a voltmeter on the battery and rev the engine.
Apr 22, 2010 | 2003 Acura 3.2TL
New battery looses power after sitting a couple of days had alt check out it ok also checked if anything was drawing power when not running everything seems mormal
disconnect battary and see what happens ,if battary holds charge put an ammeter on the earth side of the battary to see if there is any current draw if there is a draw remove each fuse individually to see which circuit it is
Feb 23, 2010 | 2004 Jeep Grand Cherokee
What would keep a charged chair from moving? It's
you may have killed the battary .you should charge your battary for 6-12 hours & every night when you use it .then if you don't use it charge it 2ce weekly for 6-12 hours & keep the battary in your house not in the trunk of your car or your garagae
Aug 24, 2009 | Health & Beauty
2001 Chrysler Sebring battary dies alternator is new
check the glove box and trunk..most time the are the route to all evil..lol.. you can see the lights because the box is closed and trunk is as well.. i hope this helps you..keith...
Mar 14, 2009 | 2001 Chrysler Sebring
Battary light would not go off
Have the battery and the alternator tested under a heavy electrical load. Some of the cheap battery testers will not indicate a bad or weak cell. Also your alternator may not put out enough amperage to keep up with the electrical demands placed upon it. A good battery tester is a carbon pyle tester. Good luck.
Feb 07, 2009 | 2005 Ford F-150
1999 Chevy Venture Van - AC not cooling, recharged and it worked for a couple of days but quit again, we figure it was a leak. The fan switch also does not work on speed 1 but will work on other speeds. ...
,, check your output voltage at the back of the alternator or a easy way is strat the car and disconnect one of the battary termianls and see if the car is still running,, if not your alternator might be bad ,, local auto zones will check it for free if u take it out ,, but don't untill u have check other things,, fan switch has a resistor in the heater core box ,, one elment might be bad in it ,, make sure the alternator is charging the battary try what i said unplug it while the car is runnging the battary terminal one of them .. don;'t do this for to long , you can blow the diodes in the alternator ,, so jsut check and if it runs then shut it off ,, its not your alt if it keeps running after u disconnect the terminal
Jul 15, 2008 | 1997 Chevrolet Venture
Invacare Pronto M51 Power Wheelchair Logo
20 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
MobilityRepairSpecia...
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
