Question about Forbidden Planet D Day Dice Operation Neptune Expansion
How long does it take Neptune to rotate on its axis
What is orotation
"orotation" is rotation misspelled.
ro·ta·tion
r??t?SH(?)n/
noun
noun: rotation; plural noun: rotations
  1. the action of rotating around an axis or center."the moon moves in the same direction as the earth's rotation"
    synonyms: revolving, turning, spinning, gyration, circlingMore "the rotation of the wheels" turn, revolution, orbit, spin
    "a rotation of Jupiter"
    • the action or system of rotating crops.noun: crop rotation; plural noun: crop rotations
    • Forestrythe cycle of growth and felling or cutting of trees.
    • the passing of a privilege or responsibility from one member of a group to another in a regularly recurring succession."it has become common for senior academics to act as heads of department in rotation"
      synonyms: sequence, succession;More alternation, cycle
      "each member is chair for six months in rotation"
  2. USa tour of duty, especially by a medical practitioner in training.
    "she was completing a rotation in trauma surgery"
  3. Mathematicsthe conceptual operation of turning a system around an axis.
  4. Mathematicsanother term for curl (sense 2 of the noun).
Origin
mid 16th century: from Latin rotatio(n-), from the verb rotare (see rotate).
Apr 11, 2017 | Miscellaneous
Why Earth rotate on its axis all the time and why the require to complete one cycle is not equal through the year?
Hi Mitiku:
Not sure why, but your question ended up in the washing machine section. Looks a lot more like astronomy.
So, to your question.
1) The Earth rotates on it's axis because it does.
2) The time to complete one rotation is constant as far as I know.
3) What's this about anyway?
Sep 07, 2015 | Washing Machines
How to calculate the volume of a oval shaped spher
The volume of a solid of revolution can be calculated by making use of some methods of integral calculus. For that you will need the exact equation of the the surface that limits the solid. Nothing you can do on a calculator.
However for the spheroids there exit formulas you can use on a calculator.
  • For an ellipsoid
If a, b, c are the lengths of the semiaxes (length of semiaxis=half the length of the axis)
V=(4/3)PI*a*b*c
  • For an oblate spheroid
An oblate spheroid is the solid of revolution formed by the rotation of an ellipse about its minor axis (here an image of the cross section from Wikipedia).
V=(4/3)PI*(a^2)*b
  • For a prolate spheroid
A prolate spheroid is the solid of revolution formed by the rotation of an ellipse about its major axis
V=(4/3)PI*a*(b^2)
Feb 27, 2014 | Office Equipment & Supplies
M heater comes on and gets hot but fan doesn't start blowing. I turn it down to make sure not to overheat the furnace. It has happened several times now and sometimes it will work for awhile then stops...
Usualy the fan absorb dust and dirt which located on its axis and support ball bearing and this making it more hard to rotate so some times rotate and some times is not. However if you are capapble you desasemeble the motor and clean the shaft axis and lubricated the ball bearings, if its is dificult for you, you can use a lubrican oil in between shaft axis and bearings this can help it run better.
The final solution is to replace the fan motor
Nov 06, 2010 | Heating & Cooling
Rotating axis is cracked and need new one. Where
Many names for this part:  TT support, turntable support, wheel support...  This site is likely to have what you're looking for:http://www.repairclinic.com/
Jul 15, 2009 | Microwave Ovens
Maytag Frontloader (Perf series) brand new Agitator off axis
Okay! We just fixed this problem on our washer. First, be safe and be sure that the electrical cord is unplugged. Then you want to take the lid panel off of your washer. Then you'll feel around under the base of the agitator/washer basket. You should notice that its feet sit inside huge springs which are fixed to the base of the machine unit. Determine whether any of your basket feet are disloged from their spring and re-insert. Make sure the fit is good or else you might have the same problem again. After you reassemble, plug in the machine and try a test spin without any clothes. Then try with a smallish load.
Hopefully this helps.
Jan 04, 2009 | Maytag Neptune MAH6700A Front Load Washer
Blurry Copies on Xerox WorkCentre C2424
There are three typical reasons for fuzzy text
1. Y-axis drum rotation problem.
2. Wrong drum temperature.
3. X-axis movement problem.
Sometimes the y-axis encoder will get oil inside and confuse the sensors, causing fuzzy/blurry print.
Most likely the drum assembly will need replaced.
Dec 03, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Can't release RA axis manually
I had one come in like this. AS you say the RA axis should be free to rotate in the RA housing when the clutch lever is released. The cylinder that the worm is machined on is binding on the axle. This doesn't overly effect normal tracking, but makes gross adjustments impossible. The only solution is to tear the mount down and finish the parts to eliminate the interference. Google astronomyboy for the how to. I have to warn you that I had to heat the cylinder and axle in the oven at 250 for 30 minutes before they would separate. don't use the wife's good oven mits!! When I finish these parts I use Soft Scrub (w/o bleach) as a grinding compound. It's basically bicarb in a jell. HTH, Geo.
Nov 01, 2008 | Celestron CG-5 Mount Telescope
IQB60M90W blue convergence axis rotated.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 10, 2008 | Zenith IQB50M90W 50" Rear Projection...
Forbidden Planet D Day Dice Operation Neptune Expansion Logo
543 people viewed this question
Top Forbidden Planet Games Experts
Lesley Cameron
Lesley Cameron
Pamela Leach
Pamela Leach
Are you a Forbidden Planet Game Expert? Answer questions, earn points and help others
