Question about Home
How do you open battery compartment door on hm3 model?
O how to open bsttery compartment door on hm3 model
2 Suggested Answers
  • 3197 Answers
SOURCE: My Craftman Garage Door Opener is approx. 7 yrs
If your keypad is the same age as your door and worked before it has probably just quit. If it is new and you have programmed it and it still doesn't work it may be the wrong one for your model opener.
Posted on Oct 04, 2009
Open battery compartment
Spray WD-40 around the compartment door and try to let it trickle inside the compartment. That should break the acid corrosion buildup that holds the door from opening.
Oct 19, 2013 | Nikon F601 35mm SLR Camera
My keyless entry pad will let garage down when code is keyed in, but when code has been keyed up to let it up it will not do so.
I assume you mean that the entry keypad works when the door is open but not when the door is closed. This usually indicates that the signal strength on the entry pad is low. Try changing the battery.
Insert a small Philips screwdriver in the opening on the bottom of the battery compartment cover. Pull the cover slightly outwards then pull the cover down. The battery in the compartment is a 9V battery. Then replace the cover by inserting the lip in the top of the battery compartment and then snap it into place.
If you change the battery quickly, you shouldn't need to reprogram the opener. If a new battery doesn't solve the problem, check what may be causing signal interference when the door is down. (Consider moving the keypad to a spot closer to the door opening. I know that we have the keypads placed on the side of the door jamb on our garage doors. When the small handheld remote units start to loose their batteries, bringing the remotes to that area that often works.)
I hope this helps.
Oct 04, 2013 | Sears Craftsman LiftMaster Chamberlain...
How do I go about removing the batteries in my HM3 thermoscan?
Replacing the batteries - Using the tip of a ball-point pen, press the battery door lock to open the battery compartment - Using your finger, press the battery release - Remove the batteries and replace with new batteries, making sure the poles are in the right direction - Slide the battery door in until it snaps in place
May 17, 2011 | Braun IRT3020 Thermoscan Ear Thermometer
Can't figure out how to install batteries in s100 mouse
It isn't easy to figure out how to open the bsttery compartment as there are no clues in the manual or on the outside of the mouse. The cover is the entire top side of the mouse behind the buttons, After many false starts, I found that if I get a thumb nail in the crack behind a button near the center and pull (push) straight back, it will pop off. Either side works.
May 09, 2011 | Adesso Computers & Internet
How do you change the battery? Mod. HM3
Replacing the batteries The thermometer is supplied with two 1.5 V type AA (LR 06). For best performance, we recommend Duracell ® alkaline batteries. Insert new batteries when the battery symbol appears on the display. Open the battery compartment. Remove the batteries and replace with new batteries, making sure the poles are in the right direction. Slide battery door back until it snaps in place. To protect the environment, dispose of empty batteries at appropriate collection sites according to national or local regulations.
Feb 09, 2011 | Braun IRT3020 Thermoscan Ear Thermometer
Open battery compartment on outside battery base??? i want to change batteries on the unit but cant open door for battery??
I finally got mine open a few minutes ago by prying it with a knife. A thin screwdriver would have been safer.
Dec 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
How do you open the battery compartment in a key pad to change the battery?
Some have a small screw that must be removed and others slide down. It depends on the model.
Dec 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Craftman Garage Door Opener is approx. 7 yrs old. Remotes work fine. Keypad acknowledges receiving code, but then will not open door. Installed new bsttery.
Oct 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
Home Logo
46 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
